Old March 9th 2005, 10:35
T4 oil sump
Anyone using Scat 1.5litre oil sump for their T4?, If so hows it holding?
T4 2666 1303s
Old March 10th 2005, 14:20
what this one........................dont tell me its bad as i havnt run it yet
Old March 11th 2005, 00:45
BWE BWE is offline
Good question. I was thinking of running a sump as well, but I could only find the one which appears to come in two halves that bolt together?
Dave
'70 GL Bug, T4 Powered!
www.boxerautogruppe.ca
Old March 12th 2005, 06:44
No, I dont have one yet but it seems not many use this sump! Most engines I see either dont have a sump or a small extension only. I was just wondering why before I buy it.
T4 2666 1303s
Old March 12th 2005, 22:13
Bill K.'s Avatar
Bill K. Bill K. is offline
On a bug the deep sump is recommended because the tuna can mounting isn't as strong and the location is prone to damage on a low car (no prob on a 914). The deep sump mounting is sturdy and the sump is strong. I bonked mine and dug up a little asphalt backing out of my driveway with only a few scratches to show for it. The driveway has a deep gutter... Now I go in/out at an angle and all has been fine. Speed bumps are another story as the sump is behind the wheels (I'll carry some 2x6's just in case)...
Tuna can (picture from www.pelicanparts.com)
Deep sump (picture from www.tunacan.net):
Also see Type 4 Oil System from Tuna.
I'm using the Scat unit from www.aircooled.net. Jake Raby recommends modifying the Type 1 filter that comes with the deep sump for better flow. Shown modified here (picture by systhesisdv):
The folded lip is cut off where the pickup tube extension passes to reduce inlet restriction. See 914.com thread for more info.
I have a RAT T4 2270 (no windage tray). Before installing the deep sump, I could get the oil light on with hard cornering or hard braking. Now it's very robust -- no sags in oil pressure at all when cornering or braking hard. I tried adding a half quart of oil before adding the deep sump, but that had little effect. The deep sump is a good $100 insurance policy, but hangs low. My car is lowered about 3" in the rear and the sump is about 2.75" off the ground at the rear. When I jump my 190 lbs on the bumper, the clearance goes down to 1.5". I think I'm hitting the bump stops, but the stiffer (23.5 mm) torsion bars helps reduce suspension travel. Attached pictures show install -- no leaks, easy install.
Another modification is to add an adjustable oil pressure switch set to 25 psi. It's tee'd off the oil pressure sender. This way, I'll get an earlier warning in case something goes wrong.
Old March 14th 2005, 04:59
Thanks for the info, I'm going to get mine.
T4 2666 1303s
Old March 14th 2005, 16:25
MattKab's Avatar
MattKab MattKab is offline
Your roads must be smooth, I'd rip one of them off within half a mile, in direction
I'll get a picture of our countries 'traffic calming by sump snatching' additions to the road surface
I suffer from oil light cornering too. I'm thinking windage tray with paddles for my T4.
Matt
Old March 16th 2005, 08:28
Chris Percival's Avatar
I have a scat sump going on very soon. My bug is unlowered at the rear, but I will still need to watch the speed bumps..
Old March 20th 2005, 09:01
MattKab's Avatar
This pair of sleeping policemen are at the end of our close. Further up the road they get a bit harsh.
I (aged 11) was hit by a speeding motorist on this spot. That's why it's there so I shouldn't be complaining.
But, I'd consider a deep sump otherwise.
Matt
Old March 20th 2005, 10:02
Trouble with them is that most larger cars and comercial vehicles go straight over them without flinching, where as smaller cars like ours need to slow down...
Old March 20th 2005, 19:25
MattKab's Avatar
Exactly Chris. What you can't see is the score marks where exhausts, engines, etc. have been snagged. I'm waiting to find the contents of someone's sump in the middle of the road
Matt
