Old March 27th 2005, 21:03
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
got any pic's of 944 master cylinder intsalled?
was just wondering how you all with 944 m/c how you ran your lines???? did you use any tee fitting for your brake light switchs..
Old March 28th 2005, 15:01
judgie's Avatar
judgie judgie is offline
no tee fitting,just i ran the 23mm to the rear brakes and the 19mm to the front.so i used the spare front port for the pressure switch.
cheers rob
Old March 28th 2005, 15:38
Did the same thing, just mounted the 23mm front bore to the front of the bug I didn't even had to make new lines, just bend the old (already new) ones; it was very cool that it did all fit rather easy
Walter
Old March 28th 2005, 18:24
Jeza Jeza is offline
Mine was a little more awkward. This could have been because my car is right hand drive- so the ports for the mc sat really close to the tunnel. The car is a 71 1302- so there is less space around the mc than on standard bugs.
I couldn't have fitted the brake light switch in their if I had wanted to.
I ran 2 new front hard lines - one to each side, from each of the mc ports for the front (the 23mm portion), and allowed enough length so i could fit these with the mc loosely in place.
I ran a short rear line to a T piece which plumbed into the stock rear line. And I ran the brake light switch off the T piece. I had to clearance the brace beneath the spare wheel well to fit the rear line to the mc.
Cheers
Jeremy
1302 RAt "GermanLook"
