View Poll Results: ????
+35mm~~~11%-20.0ft~~~52.1%scrub 1 33.33%
+42mm~~~16%-21.0ft~~~34.6%scrub 2 66.67%
Voters: 3. You may not vote on this poll
Old May 26th 2005, 02:22
rip's Avatar
rip rip is offline
need some wheel opinions
I've been trying to run wider wheels on my bug. Right now, without getting into too many details I've got a choice to make and was hoping for some insight.
I hope to run a 17x7 rim, and the deciding factor is the offset. +35mm or +42mm.
With the +35mm I don't lose as much turning radius ~11%
With the +42mm I lose ~16%
But with the +35mm offset the scrub and bearing wear would be larger. I havn't been able to find the original scrub radius, it would increase in the order of ~52.1% and the edge of the wheel would be ~60mm further out (compared to stock) thus that outer bearing would wear faster.
With the +42mm offset the scrub and bearing wear are not as bad. Scrub radius is now about ~34.6% and the edge of the wheel would be ~52mm further out (compared to stock).
the edge won't be too much further out, when you compare the two, but the scrub and turning radius differs a bit.
thanks for any opinions
Rip
