Old April 27th 2005, 16:35
WipEout WipEout is offline
Memo's "Euro-style" headlamps
Hey everyone! Been a while! Wouldn't it be great if someone made headlamps similar to Memo's (with the built-in turn signals and fog lamps) only minus the fog lamps? Or does someone make lamps like that already?
Old April 27th 2005, 20:37
Like these???
Kafer_Mike
Old April 28th 2005, 04:58
Yeah, but those are the same things, only the whole lens is clear instead of yellow tops like the Memos. If you check the description on Real Source's lamps, it describes the lamp as having three divisions, only different applications. I might just go for Source's anyway, I like the idea of clear signals and whatnot. Especially if Memo is having troubles with their communications as of late...
Old May 10th 2005, 10:41
Tompa Tompa is offline
clear lenses headlamps
I just wanted to show my Euro-style headlamps
Old June 6th 2005, 00:05
undecided undecided is offline
those lights have blinkers in em? i thought they were just hlight, brights, and running light. do you have to hook one of the bulbs up to a blinker relay to get that? or are they like that already?
Old June 6th 2005, 18:03
I made an order from memo a couple of week ago and had no problems. I got everthing very quickly. Jake also ordered these headlights and lail light lenses for his girlfriends 1303 and they shipped quickly. :agree:
Old June 7th 2005, 17:16
BWE BWE is offline
WipEout,
I have the Memo lights on my bug. the top segment is clear and could be easily run into your turn lamps or running lamps (what I did). I don't know if the stock flasher relay would be able to support the load, but there are enough aftermarket that have enough rating.
Cheers,
Dave
'70 GL Bug, T4 Powered!
www.boxerautogruppe.ca
Old June 20th 2005, 16:39
awesome thanks for the input and sorry for the late reply (finishing the semester). Yeah undecided-- according to Memo's website, you can make the top running lights into flashers (just as BWE suggested, with different relays, etc). Thanks again for the input, fellas!
