Old May 26th 2010, 04:47
maniac maniac is offline
My Project....Superbeetle Conv. 2.4l with EFI - Megasquirt
Hi,
don´t know where my oldeer Thread is, so i will show you some Information about my project.
First my Convertible
Full Docu about the resto at http://kcc-niederrhein.de/index.php?...egory&catid=19
Last Winter build a Typ4, 2.4l ..hooked up a efi
best regards
Markus
http://www.carbonworks.de Interior Goodies in 100% cfk for your Superbeetle
http://www.kcc-niederrhein.de Käfer Cabrio Club Niederrhein Germany
Old May 26th 2010, 06:54
Heres a pic from the dashboard
Old May 26th 2010, 07:34
Very nice work. Love the dash.
Old May 26th 2010, 07:37
will make same better pics, cause this pic is from the last year and a little bit dirty
Old May 26th 2010, 09:02
Xellex's Avatar
Xellex Xellex is offline
great looking car! Love the dashboard, it is similar to what I did a few weeks ago Mine still needs some upholstery and one of your CF panels tho :P
www.vw1303s.com
Old May 26th 2010, 12:59
Great job, I'm going to go through all of your gallery now!
Rich
Old May 26th 2010, 15:04
Love the wheels, what are those?
Old May 27th 2010, 01:46
Wheels are Tomason, located in Germany Essen. Its a local Enterprise
Dimensions are 8.5x18 ET35 in front and ET15 an the rears
Old May 27th 2010, 07:14
karmann79's Avatar
karmann79 karmann79 is offline
well done
Old June 8th 2010, 07:41
What the hell
After first Startup...ecu runs fine, but no oilpressure
Only 0,5-1bar pressure at 2000 rpm....that sucks
Old June 14th 2010, 05:19
Hi Markus! You guys should see the car in person,it´s very well done! Did you bleed the oil lines and oil cooler properly Markus? Also check your oil pressure gauge or swap it with a gauge that you know works.
Another possible reason could be that your pick up tube inside the case isn´t properly fit or too high above the sump.The pick up tube may not be able to suck enough oil if it is not properly installed.That would be a problem because you may have to open the case again.I hope that´s not the reason and it is something simple..
Old July 23rd 2010, 20:52
SportyBug SportyBug is offline
I love this dash, can we get more pictures? You did this with 914 gauges correct?
I've seen a few custom dashes like this on here and would love to see an in-depth "How to/DIY" from start to finished product cause I would like to do the same for my project
Mike
Old July 26th 2010, 02:57
we have opened the case again and hope to find the problem
one of the plugs blocks the oilchannel (only 50% of the diameter are open)
@Turbo
we have checked all things befor open the case again..
Have to drill out the plug and hope that the oilpressure will ok now.
Another little Proble was the Mahle bearings...
seems they are not fitting like K&S bearings, 6/100mm smaller in diameter than the K&S bearing...that sucks
Change also the mahle bearings to kolbenschmidt
Old August 23rd 2010, 05:29
Engine is back in car and oilpresure ist fine...
cold engine= over 5bar
Next friday we will programing the EFI.
Car runs up fine already, only need to program some finetuning
bst regards
markus
Old August 30th 2010, 05:16
**** happens...
at 3500 or lest at 5000 rpm, engine ecu gets offline...
no idea why....grrrr
think theres an electric bug in the system...alternator damaged no load
Sometimes the vr is not registring the tooth...
for the video-junkies.
Video "first run"
http://www.youtube.com/watch?v=gcRMUnd_A70
