Old October 17th 2005, 19:46
Uber Affe's Avatar
trying to fut my mirrors...ARRRRGH! help please.
I should have had the holes filled when I had the chance before the pint when on and now there'll be fifty bajillion holes in the side.
Bottom line: I'm trying to fit my Talbot replicas to the side and finding that the metal is rather thin around those areas and the bolts are rather long.
I'm guessing spacers, but considered chopping the bolts down.
Ant who...It's just a huge pain because the spot they're going is seemingly impossible to reach from the interior side of the door and it is turning into a real bitch to get the screws to stay 'til they are in the holes...if and when they ever reach the thread holes!
Any of you run into a sinilar proble here? Did you just cut out a big hole for your tools to fit or figure something else out?
If this is too erratic to follow..let me know and I'll explain better.
Damn it! so close to completion!!!!!!
Old October 23rd 2005, 11:17
Bill K.'s Avatar
Bill K. Bill K. is offline
It helps to locate the mirror based on where you can get the bolts to from the inside. The OEM mount can get in the way. I located my mirror so the mounting bolts went through the door skin only. I located the first bolt as close to the OEM mount as possible and still be able to get a wrench on it, then made template for the mounting holes of the mirror to drill the other holes using the first hole for alignment.
Have someone hold the mirror where you want to put it and test the visual alignment from the drivers seat to ensure you can see where you want to see behind you before committing to holes.
Buying shorter bolts is always easier than modifying bolts. Especially in tight spots like this because getting the first thread to start is critical. If you need to cut the bolt, do it with a nut already on so the nut can chase the tread clean after cutting the bolt.
A ratcheting combo wrench works well. Finger contorsions and patience are also required...
