Old December 9th 2005, 22:07
Leaking between!
The area where the gearbox meets engine is quite wet with oil!, Is it most likely the oil seal at the flywheel or something else?
T4 2666 1303s
Old December 9th 2005, 23:55
super vw super vw is offline
Is it engine oil or transmision fluid? if it's engine oil (most likely) than it usually is the rear main seal (seals the crankshaft/case), The seal is cheap, but getting to the seal requires engine removal (assuming you can do that yourself, it's not to much fuss replacing that rear main)
BUT... i would recomend cleaning that area real good (almost spotless) so you can pin point the problem (break clean looks great for this!). It could even be the case halfs, oil plugs...ect
Just think of all the deatailing you could do with the engine out though ! HOW FUN!!!
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old December 10th 2005, 03:07
Thanks Johnathan, will have to take the engine out anyway, changing to 1.48 rockers.
T4 2666 1303s
Old December 10th 2005, 11:52
Cool... whenever we have engines out (vw & Porsche motors) we always replace the rear main for good measure.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old December 10th 2005, 19:45
mikko k mikko k is offline
And when I take engine out, I'll chance the trans seal too. Easy to do at that time. VW part# 113 311 113 A (or C).
Old December 11th 2005, 09:15
Thanks guys, appreciate your help.
T4 2666 1303s
