Old December 7th 2005, 17:04
JiI's Avatar
JiI JiI is offline
Question 915 best year choice
Looking to hook up a Subie to a 915 tranny in a 1600 lb. kit car. What would be the best year to use? Gearing? Mostly looking at sporty performance and a nice freeway flyer. (okay, the occasional smoky burnout... )
JiI
"If at first you don't succeed, give up, there's no sense in making a fool of yourself."
Old December 8th 2005, 17:26
typ4boy's Avatar
typ4boy typ4boy is offline
hi , choose one from 76 on as these are pull to realease(clutch) idealy later the better, my fisrt install was a mag cased push to realease , nightmare on elm street , until we hydrauliced the clutch, and made a realease arm from a vw unit and porsche unit. my 2 other cars feature 78 box and 87 box. good luck you will not be dissapointed the a 915. all the best lee L.A.P
Old December 9th 2005, 05:03
Lee,
How did you sort out the master cylinder? I'll be needing one for my 03 cab with G50..
Rich
Old December 9th 2005, 20:49
typ4boy's Avatar
hi rich, is your car LHD??????........ if not your in trouble, all our cars are LHD its easy to put next to brake master cylinder in LHD car and make bracket similar to the way the brake pushrod works , phone me mate and ill talk you through it, all the best Lee L.A.P
Old December 10th 2005, 08:07
Mine's RHD... I don't really want to replace the other pedals as the brake master is nice with the 996 brakes... Do you think there is enough space between the tunnel and brake m/c if I do some tweaking?
Rich
Old December 11th 2005, 11:42
JiI
You may want to consider the size of the CV's as well. I have made many posts regarding this. Just do a search..
@Lee: You made a release arm from a 915 and a VW unit: Interesting: did the weld hold up???
Tnx,
Walter
