Old April 2nd 2006, 19:49
flat flat is offline
Audi TT brakes on Bus..the cheaper way
I've had a TT kit for the Bus for a while, but the billet hub makes it quite costly. I've figured out a cheaper way using late bus (73-79) hubs.
This kit uses Audi TT rotors and Golf A4 (VR6/1.8T) calipers. The disks are 312 mm x 25mm units. The hubs are modified 73-79 Bus disk hubs. By modifying existing hubs, costs can be kept low. The hubs are machined for 5-100mm bolt pattern and tapped for M14x1.5 wheel bolts. Caliper brackets are fabricated steel and require no modification to the spindle (will work with stock or flipped spindles)
www.vdubengineering.com
