Old December 3rd 2006, 09:07
Bad bug's Avatar
Bad bug Bad bug is offline
Cleaning the inside of chasis
Hello all recently got my new frame head to convert a superbeetle chasis to a standard chasis. Can anyone tell me the best way to clean the inside of my chasis so that i can paint it.
Old December 3rd 2006, 12:53
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Unfortunately, the only method I know of is to have it chemically dipped/stripped.
Due to the confines and the fact that it is several feet long, reaching your hand with a solvent soaked rag inside to clean isn't a good option.
Or...get a bunch of Smurfs with flashlights and mini power-washers!
(Did I just show how cronologically advanced I am with the Smurf thing??)
Old December 3rd 2006, 14:14
Bad bug's Avatar
I was thinking about a power washer with a degreaser as fluids to remove oils.
Old December 5th 2006, 23:50
AusSuper's Avatar
AusSuper AusSuper is offline
Drill out spot welds on the bottom plate, remove clean spray, weld shut, only way i can see that would work properly so you can cover the inside of the tunnel with paint again, hope that helps
Old December 6th 2006, 00:22
Bullyboy Bullyboy is offline
I just washed mine through all the available holes with the pressure washer. then sprayed the rust paint inside. It covered quite well and looks pretty good.
