Old May 17th 2006, 21:26
Russ1302 Russ1302 is offline
Moving Sale!! lots of type 1, type4, and porsche parts.
I'm selling a ton of VW and Porsche Parts. Everything must go. Here is a list of the first batch. I'll be taking pictures and listing these items and more on thE bay, starting Sunday night. If anyone is interested in anything here,
Email me @ russ1302@gmail.com
Parts are located in Milford MI
BMW M3 Oil Cooler
T4 Bus Heater boxes
914 1.7L heads Used
T4 1.7L Head Used
90mm T4 Domed Pistons with pins
94mm flat top Piston Cylinder set
90mm domed Piston, Cylinder set
911 fan shroud (not for vw engine)
914 heat exchange
T1 Dual ports head tins
911 shifter
Corvair tensioner pulley
6 disc cd changer
Empi Shifter
944 spindles
71-72 super front fender
71-72 super rear fender
71-72 super engine lid
Toyota MR2 Fan
Engine Case
944 Stub Axle
944 Torsion bars
D jetronic system
914 trans hanger
914 Flywheel 2.0 215mm
914 Pressure Plate 215mm
914 Clutch Disc 215mm
Super beetle Rack and Pinion w/ tierods
66mm T4 cranks
stock cams w/gears
T1 cam gear
911 Shift rod
914 tail shift
901 nose cone and shift rod
901 Tansaxle seal kit
Weber DCNF Parts
914 engine case
914 Flywheel 210mm
set of dual solex and t4 manifolds
