Old February 19th 2007, 17:24
Koji2528 Koji2528 is offline
Custom door panels
Hello, I have modeled some custom door panels with a 3d program, and i was wondering what you guys thought. Also, what a shop would charge to construct such a panel, since I lack the skills and the machinery involved to do so~
I would want the material to be leather, perhaps black, thats the color I just slapped on the polygons to give them some depth.
Old February 20th 2007, 06:08
They look relatively simple, the hardest bit would be trimming the handle. The rest could be a flat board with thicker foam cut to your shaped sections to give the raised look. I'd source the handles etc first and work around them..
Rich
Old February 21st 2007, 08:53
ajsyrup ajsyrup is offline
check lokar.com they have that one oval looking handle u have there the lever style handle i am not sure there is a company billet specalties that has alot of that stuff both pricey but when u get into custom what else do u expect
Old April 25th 2007, 08:48
1303mark 1303mark is offline
personally i would alter the desgin of the handle so that it is a screw on part that will simplify the probelm with covering it.
if you are willing to NOT use foam but just to use MDF it would be relatively straight forward to make.
plain rectangle base, 1/4 inch hardboard or aluminim panel. then glue/screw on 1/4 inch mdf cut to you oval shapes, fillet the edge with fillers then cover in black vinyal.
much easier to do than foam, and you could do it yourself.
i have made these door cardds fro my bug
i also made these but i didnt use them after i fitted a roll cage.
i can get the white ones made in fiber glass, £100 the pair.
