Old May 21st 2007, 18:40
chug_A_bug's Avatar
Dumb ?
hey well I have a 69 but it's a Swing Axle and now that I have my new 74 it's an IRS how Do I lower it??
thanks
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old May 21st 2007, 18:59
Shadowbug's Avatar
easy, pull the torsion bar and rotate it a couple of splines
a few pics of my project
Old June 13th 2007, 22:01
fate fate is offline
me to
I just picked up my first beetle, '71 super. I have an addition to this q. Will this method of lowering the rear ( I hope to drop at least 5") throw my camber way out like some of the cars I've seen? Also will this method even get my that low or will I need to do something else?
Old June 13th 2007, 22:19
The cars you seen with extreme negative camber on the rear, are swing axle cars. Look under the rear of your car at your axle. If you see a rubber boot at BOTH ends of axle (by wheel and by tranny) then you have a IRS. If you only see ONE boot at the tranny only, you have a swing axle. The IRS will not give extreme camber when lowered.
Old June 14th 2007, 15:35
ellobo ellobo is offline
This isn't related to the IRS question....But when you have such negative camber on a swingaxle. How do they get the trannny oil up the axle tubes in order to lubricate the wheel bearings?
Old June 14th 2007, 15:57
gonebuggy's Avatar
you can get some decent camber with IRS.... just need to go 3 splines or more
as for your REAL low swing axle, you should replace the bearings with sealed, lifetime lubricated ones. problem solved.
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old June 18th 2007, 16:23
Right on, I know i have I.R.S. but didn't know if it was exempt from the negative camber.
