Old May 20th 2007, 10:55
Fuscazul Fuscazul is offline
Carb Rebuild
I'm a beetle newbie.
Need a dummies guide to carburator rebuild. I have a stock 1973 Brazilian 1500 beetle with a Solex 30.
The carb floods frequently. Gasoline drips onto the engine and the engine stalls. After about 1/2 hour of dripping. It restarts like nothing ever happened.
I've played around with plenty of engines but never dealt with carburators. Where shall I begin?
Thanks,
Al
Old May 20th 2007, 16:28
Pillow's Avatar
Pillow Pillow is offline
You can do it!
It sounds like the float or float bowl metering valve is to blame. The valve is included in a rebuild kit.
Once you break open the carb you will see it is a piece of cake. Soak it in carb cleaner and then blow out with compressed air. Then reassemble... The tough part is tuning it again.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 20th 2007, 21:10
Thanks, Ill try it
