Old May 29th 2007, 11:36
elev8_dude elev8_dude is offline
Need MAJOR MSD Distrubutor HELP (Timing)
I can't figure out where I'm supposed to be on my timing. I get back fire in the carbs and sometimes at off. I have no real response on shifting and then it kicks in. I have flat areas and in 4th I can feel it hesitating
PLEASE HELP. I can't figure it out and I burnt out on it. Thanks
What bushing and spring combination would you recommend with this set up.
Vehicle: 1969 VW Beetle
Engine: 1915cc (Type 1)
Crankshaft: Forged Counter Weighted
Cam: C35
Compression: 8:1
Power Band: 3,000-5,000
Valves: 40x35
Mixture (Air/Fuel): Slightly Rich
Fuel Octane: 89
Carburetors: Dual 44 Webers (w/CB Performance Update Kit)
Ignition: MSD 6AL (Rev Limiter @ 6,000 RPM)
Coil: MSD Blaster SS
Distributor: MSD Distributor (8485)
Spark Plug Wires: MSD Wires (3193)
Spark Plugs: Bosch Supers (7401)
Battery: Optima Red Top
Alternator: 12v
Old May 29th 2007, 23:32
super vw super vw is offline
Well first set your base line ignition timing according to your engine specs and elevation aswell as fuel.
I am at 4000 feet so i can get away with running a full 36 deg of advance, but at lower altitudes you can expect to be around 28-32 deg. Once it's set and feeling ok.... then play with your carbs.
unless you can read plugs really well (kinda hard once fine tuning is needed) i would invest in a Inovate LM-1 fuel/Air ratio meter, very accurate and easy to use.
Also, before you start playing with your jets you need to get your float level inside your carbs spot on, your hesitation could be from a lean out condition durring those RPM's. you would be suprised what 1-2mm of float level change can do. i played around with mine (40mm dellortos) for a weeks before i found the spot where there was no hesitaion from 2500-4000 and 6000+. the "JETTING " was spot on, but the floats where off by 1mm).
Now you say your running a little on the rich side? Do you have a ratio number it was at? expect to be around 12.0 give or take one percent on a performance motor.
Also, if you have a meter you need to test it underload (While driving) to see where your rich and where your lean... then you can take action from there.
I gotta say carbs are a pain in the *** compaired to Fuel injection, but ussualy once you get it set you dont have to fiddle with it much afterwards.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old May 29th 2007, 23:33
Oh... BTW, i would run at least 92 Octain, there is really no resson to run anything less if you care about your motor and performance.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old May 30th 2007, 08:17
Thanks for the response. I will look at all those items mentioned. I highly appreciate it. Its been driving me nuts. Hopefully it will get it down.
