Old April 7th 2007, 04:16
petevw's Avatar
petevw petevw is offline
Tore down the engine today......
Hi guys,
Updated from:
http://www.germanlook.com/Forums/showthread.php?t=8173
Not working today, so i tore down the 2332, that was pulled a couple weeks back, which blew in Dec. Here's what i found,
The exhaust valve had no face, and the tip was ripped off at the keeper:
'72 super
'65 bus
'52 split
Old April 7th 2007, 04:17
petevw's Avatar
Head split in 2. Thinking the barrel split, and the piston went sideways smashing into it:
'72 super
'65 bus
'52 split
Old April 7th 2007, 04:18
petevw's Avatar
Wiseco piston/pin rods stayed in one piece:
86C broke in 3:
'72 super
'65 bus
'52 split
Old April 7th 2007, 04:19
petevw's Avatar
The other side (1&2) looked good:
So, the stocker 1600dp is going back in for the summer. Need to finish the other 2332 that is sitting on the stand. ;D
I'll get the rods/crank looked at and serviced next week. Part it all out. Hopefully i can get some cash at the local swap meet next weekend (John's Bug Shop).
Anyone need some spares?
'72 super
'65 bus
'52 split
Old April 7th 2007, 05:33
zeroaxe zeroaxe is offline
Dear god! I feel sick to my stomach!! Sorry to (hear of) see your loss! Best of luck with the other motor and recouping some cash with the other parts!
Zeroaxe
Old April 7th 2007, 18:05
gonebuggy's Avatar
What all will you be selling bro?
Cheers
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old April 7th 2007, 19:32
Bad bug's Avatar
Bad bug Bad bug is offline
Wow that's one huge lost, is the crank still good. Those inlet valves aren't unshrouded at all.
Old April 7th 2007, 22:26
petevw's Avatar
Cheers
I'll start putting things aside soon. Most of my spares. Need some $$$ to finish other projects. Some of this stuff will make it out to the swap meet, other will hit the 'net as they come off the car. If you see anything you want let me know.
Off the top of my head:
Hi-torque starter
JSC 1.4 rockers
Autocraft 1.4 roller rockers
rocker shims
bugpack solid rocker shaft for stock arms
adjustable chromoly pushrods x6
lashcaps various thickness
copper head gasket sets (0.20, 0.40, 0.60)
Pauter ALU/Chromo 5.7 chevy journal rods
94mm Cima cylinders x7
IF the crank rods check out OK:
-84mm 4340 Bugpack chevy journal crank
-5.7 Bugpack H-beam race rods
12lbs flywheel
1700lbs Kep PP
4-puck unsprung disk
magnum straight cut gears
extra chromo 8mm headstuds
Jaycee pushrod tubes x6
Airkewld polished 911 fan/alternator, stand, linkage, carbon shroud (this is my "extra" setup)
Power Tuning Parts fiberglass 911 fanshroud for VW (the one that came off this motor)
complete drysump setup (pump, lines, cooler, tank, autocraft sump pickup)
Electromotive TEC2 with sensors
Superflo valve covers
3 Wiseco pistons 48x38 valve notches
K-800 valve springs with titanium retainers
2inch merged stepped header with O2 bung and 40 series flowmaster
3-bolt nosecose
new 96plate mesa cooler
21mm, 30mm oil pumps
I'm sure there is more. I'll have to look.
'72 super
'65 bus
'52 split
Old April 7th 2007, 23:04
chug_A_bug's Avatar
Hey Pete
those 1.4 rockers you have
would they work with my 1641 DP
36mm Webers and I was told that the Cam was one Size up from Stock
if so how much ?? and would I really get that much out of them then stock?
and if you are going on tue could you Bring them?
thanks
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old April 8th 2007, 15:25
CLKWRK's Avatar
CLKWRK CLKWRK is offline
ouchie,
Pure carnage!
I am interested in getting hold of both dry sump pumps.
Bryan
GL ghia restoration:
Old April 9th 2007, 21:09
petevw's Avatar
Originally Posted by chug_A_bug View Post
Hey Pete
thanks
I'll bring them on Tues. I don't know how a 1.4 rocker will be on your cam, and how the motor will act afterwards. No clue.
Bryan, i'll bring the pumps.
'72 super
'65 bus
'52 split
Old April 9th 2007, 21:29
OUCH !
Sorry to see the damage Pete ... get that 2332 Turbo built !
Old July 10th 2007, 00:01
speedy's Avatar
speedy speedy is offline
from my experience 2275 turbo will be outh when it goes wrong but the smile is worth it
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
