Old May 11th 2006, 05:34
speedy's Avatar
speedy speedy is offline
positive camber problems
i have a problem with excesive positive camber on the front of my bj beetle ,
i have a puma beam at stock settings and dropped spindles , one side has camber of 0 and the other side has camber of +0.5 degree's i have fitted extra camber adjusters and this is the best i can get any ideas on how to get more -ve camber ,or has anybody els suffered with a similar problem , any input would be appreciated
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 11th 2006, 12:44
Hebster52's Avatar
Hebster52 Hebster52 is offline
Same answer here as I posted on VZi: :agree:
You can adjust the camber by untighten the upper balljoint and turn the conic hexagon part shown below.
Old May 11th 2006, 22:38
Local racers looking for extra neg camber have their upper arms bent.
Old May 12th 2006, 00:19
Bill K.'s Avatar
Bill K. Bill K. is offline
i recently found out my car has a similar problem with similar parts. new adjustable beam, new CB dropped spindles, extra eccentric adjusters and the left side only adjusts to 0 camber. The right goes to -1.2 degrees. left has as similar range of movement as right, but only adjusts in +camber. i can only guess that the control arms (new) are bent on the left side. i've got a pair of new arms for the left on order from aircooled.net to see if that fixes it.
Old May 12th 2006, 01:22
speedy's Avatar
bill i think this may be a problem with the spindles as i have only changed them from standard and experienced this problem,before i fitted them it was fine, i was thinking about either ,shaving 2-3 mm of each bush on the top tube of the beam shortening the torsion leaves and re drilling them ,this should just give me enough -ve adjustment what do you think ?
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 12th 2006, 02:05
Bill K.'s Avatar
The guy who did the alignment thought it might be the spindle also. I don't expect CB Perf spindles to be wrong. What spindles to you have? Did you remove the control arms during the swap?
I had my control arms off and was wondering if somehow I didn't get the left side seated correctly. I'll check that before I remove them.
As far as your idea for modification, I don't know if that would work. Bending the arms does for sure, but it's tricky from what i've read.
Old May 12th 2006, 06:07
speedy's Avatar
The arms did not come off when i did the spindle upgrade , i don't think it is a fault with the spindle machining, i think it is the actual design ,mine are cb spindles also the spindle back plate is alot thicker so it may be that the top bj position has been moved outover to give room for the compensator nut giving the positive camber,without taking them off to compare i don't know for sure, iwas thinking of moving the arms in by turning down the urathane bushes in the end of the arms ,i don't have the equipment to bend the arms and am not sure what it will do to the geometry if they get slightly twisted etc when bent ,just out of interest how would you bend the arms?
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 12th 2006, 08:23
Thing that determines where your arms sit in the beam is the dimple that the grub screw sits in, so turning down the bushes will have no affect.
Old May 13th 2006, 02:04
Bill K.'s Avatar
Originally Posted by speedy
...just out of interest how would you bend the arms?
...with a BIG press and skill/experience (I don't have either...)
If one side is excessive positive and the other is excessive negative, then it could be that the torsion springs are not centered and the center grub screw needs to be moved. That doesn't sound like your problem, but note worthy.
It could be tough relocating the end grub screws pockets in the torsion springs like you suggest -- material and configuration...
I'm going to call CB about my situation and see what they have to offer.
Bill
Old May 13th 2006, 03:38
speedy's Avatar
after i turned down the bushes i was going to turn the torsion leaves over 180 degree's re center them and shorten if needed and then redimple them to move the arms in , i have the machines to do this at work ,before i do all of this i am going to measure everything and see if i can come up with another solution , may just recenter the leaves as 0.25 degrees on both sides unloaded may be alright as they go more negative as they are loaded will update you with the outcome of my findings
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 13th 2006, 04:57
Turning the leaves over could cause them to snap because of the different twit direction. Maybe you could bore the stock holes slighly deeper in the correct direction or maybe there is slight difference between your top & bottom leaves grub screw position?
Old May 15th 2006, 12:08
Bill K.'s Avatar
FWIW, CB says they have never seen a bad spindle cause this issue and suggested to check the control arm for bend, the ball joint orientation within the control arm (notch lined up), or swap the eccentric. It doesn't take much...
Even though my beam is "new" it doesn't mean the arms are. They could be remanufactured and not be straight.
Old May 15th 2006, 13:31
speedy's Avatar
well it has been raining today so not much got done ,steve i had a look and the first thing i am going to do is to turn the leaves left to right on the top to see if this makes a difference, if that fails to make a difference then may have to look at a more radical solution , bill i would be interested in the outcome of measuring the old and new arms against each other ,to bend one of the arms would take quite an impact i would of thought, has your beam got urethane bushes or bearings in it , anyway one way or the other i am sure we will sort it
cheers jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 16th 2006, 20:37
speedy's Avatar
well i had the bottom leaves out today and measured everything up ,the dimples were an equel distance from the ends of the leaves ,the beam adjuster was off center ,all the arms were a snug fit in the bushes possibly 1 mm movement ,measured the top and bottom torsion tubes and found the problem when the tubes have been welded on or narrowed in the past the top tube has been welded offset to the LHS by about 4mm, so pulling one side in at the top and the other side out at the top , this is i suspect an aftermarket mexican-brazilian beam ,utter s***
i am going to take the beam off tommorow and take it to work with me ,remove the top bushes and remove the offending 4mm on the LHS replace the bushes and redimple the torsion leaves hopefully this will give me 0-to -0.5 -ve camber on both sides , time will tell
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old May 17th 2006, 00:24
That's great, it looks like you got to root of the problem.
