Old August 5th 2007, 22:05
Eatoniashoprat's Avatar
Is this a bad idea?
So I've got the rear tranny mount turned around to move the suby ahead and I'm fitting the tranny in (T1) to build the front mount but the reverse light sender is hitting the torsion tube. I was thinking I could just cut into the torsion tube an inch or so to make clearance for it but also read that this might be a bad idea. Any suggestions? Is there somewhere else I could mount the sender?
1302 EJ20 turbo
Old August 5th 2007, 22:23
Bug@5speed(US)'s Avatar
Regarding your idea (cutting torsion tube)
PM your email address, I will send you some info on our products.
Your type I may not be up to the job if power is to high, if you decide on a 5speed down the road our parts or similiar can help you. NO cutting of the torsion tube needed
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 5th 2007, 22:26
Depending on your set up, the type I may not be up to the job if power and torque are to high. If you decide on a porsche 5-speed box down the road our parts or similiar can be of help to you. NO cutting of the torsion tube needed.
Will email plent of info, FYI.
VR
Alex Olaverri
Tele: 973 204-5463
Old August 6th 2007, 14:24
I just removed the reverse switch and fitted the standard blanking plug, even that had to be ground down a bit to clear...
Rich
Old August 6th 2007, 16:32
Rich
Thats kinda what I was thinking, but I still would like to have reverse lights, I'm planning on using a berg shifter but don't have it yet, I'm wondering if you could wire a switch into the shifter reverse button or something, just thinking outloud...
1302 EJ20 turbo
Old August 6th 2007, 19:42
Do what Ricola said with the blanking plug. I saw a contraption made up on an early bug once. It was a door light switch mounted on a bracket on the shift coupling, when reverse was selected the switch touched the cover plate turning the lights on. The other way is a fairly rare part these days, its a sensor that fits on the speedo cable and turns the reverse lights on if the car moves backwards, it can take almost a complete wheel revolution for the lights to come on.
Old August 6th 2007, 23:52
Thats a good idea with the door switch Steve, I'll have to play around with that a bit. I just got the tranny to where it needs to be today and now to get the timing covers to fit in there! tons of fun
Mike
1302 EJ20 turbo
