Old June 15th 2007, 14:08
tom'72's Avatar
tom'72 tom'72 is offline
uniball setup with stabiliser bar?
I'm going to convert my IRS rear setup from the stock torsion bars to a unibal system with coilovers.
Is it a good idea to add a stabiliser bar to this setup or better not?
thanks
Old June 16th 2007, 09:20
If select the correct spring rate, you really don't need a sway bar, except for tuning.
Old December 29th 2007, 19:51
Angelo Amato's Avatar
update ??
Hi, any update on this topic ?
I've got uni-balls on the rear of my car now with coil overs. have a bar on the rear too
not driven it yet. any issues on this set up - is bar needed ?
cheers, Angelo
Type 3 Fastback
Old December 30th 2007, 12:31
1303R's Avatar
1303R 1303R is offline
lots of pics please more different makes the better, i need to justify getting some also any mods needed to stiffen upper or lower mountings for the coil over.
Old December 30th 2007, 14:49
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
I wil recomend it. specially if you plan to do any autocrossing.
I have coilovers rear and a 19mm bar. im upgrading to a thicker/stiffer to get bether turn in.
Old January 1st 2008, 07:44
skywalker
I bought a 19mm Porsche 968 Clubsport sway bar to mount on my splitbus with IRS.
It's not bold on yet, but that 'll be an easy job.
