Old April 2nd 2008, 16:46
Eatoniashoprat's Avatar
Hidden Antenna options
Hi, I'm looking for a hidden antenna solution for my super beetle. I need to have an antenna for radio however I don't want anything you can see, including the shark fin thingies like BMW has. Does anyone have experience with any sort of hidden antenna? Thanks
Mike
1302 EJ20 turbo
Old April 2nd 2008, 17:24
A friend had success when he insulated his hood and used it as an antenna, I've also seen them fitted under the running board running parallel to the road.
Old April 2nd 2008, 20:11
smithe68
A buddy recommended one of these:
http://www.ecshylites.citymax.com/page/page/761353.htm
I have used one like this with good results and you can usually find one at you local autoparts store:
http://www.thehoffmangroup.com/autol...odinc=antennas
I had mine mounted to the roof under the headliner. They run about $40.
But have seen one mounted under the front bonnet of a beetle with double sided sticky tape. However if I remember they don't like direct contact with metal.
Old April 7th 2008, 09:19
Thanks for the replies guys, I didn't see these replies right away and I ended up buying this one from Metra. I've heard it works well mounted under dashes.
http://kcautosound.com/Metra-Hide-aw...na-pr-427.html
1302 EJ20 turbo
