Go Back   GermanLook Forums > General > Feedback, Suggestions, & Help
Old June 23rd 2008, 17:39
volky68's Avatar
volky68 volky68 is offline
Member rides page
Superman,
Not sure if you were aware of this, but when you click on any of the images of the member profiles you get the following error:
Not Acceptable
An appropriate representation of the requested resource /Functions/ViewImage.php could not be found on this server.
Apache/2.2.8 (Unix) mod_ssl/2.2.8 OpenSSL/0.9.8b mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 PHP/5.2.5 Server at www.germanlook.com Port 80
Old September 22nd 2008, 00:34
volky68's Avatar
Do we have plans to fix this issue?
Old September 22nd 2008, 10:20
Superman
Yes, I knew about this and have known for too long. There are many changes and fixes to come, this being one of them.
Old October 14th 2008, 22:28
Unregistered
Members Rides Pictures
It would really be cool if you could fix this. The members photos are my favorite part of this website.
Old October 15th 2008, 01:16
Superman
I will try to have it taken care of this week. The honest answer is that function wasn't designed by me so before I can fix it I have to learn how it works and I haven't had the time to do that yet.
Old October 15th 2008, 14:27
volky68's Avatar
Superman,
It seems the file ViewImage.php is missing based on the error I get. It could be as easy as restoring the file from backup of the site if you have it.
Ed
Old October 15th 2008, 17:51
Superman
The file is there, I wish it were that simple
Old October 19th 2008, 17:05
smbrewer's Avatar
smbrewer smbrewer is offline
OK, down and dirty fix is in place, that should hold until I figure out the reason the script isn't working properly.
Old October 20th 2008, 00:23
volky68's Avatar
Thanks for the fix. I was able to pull up the images.
Old October 20th 2008, 00:43
Superman
Thank you Steve, I (we) really appreciate the help!
Old October 21st 2008, 00:42
AIRSICK's Avatar
AIRSICK AIRSICK is offline
Thanks!
Hey thanks to all who helped fix this!
Old May 7th 2009, 22:21
volky68's Avatar
Is the member profile page going to be available again on this site?
Old May 8th 2009, 09:35
Yes,
The main page still needs some work fixing broken links, but you can access it here ...
http://www.germanlook.net/html/main.php
Old May 8th 2009, 10:04
Man it has been a long time since I have seen that page. Nice to see it again.
Good work man.
Old May 8th 2009, 16:40
Jim's Avatar
Jim Jim is offline
Guys...you are magicians!!! Thx!!!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
