Old January 17th 2011, 06:07
F4P's Avatar
F4P F4P is offline
F4P project SUB 4x4
hello every body
first i apologized for ma bad English .... i'm French
my project:
vw 1303 1973
engine Subaru ej20 twin turbo
gearbox Subaru wrx with all the transmission to make a 4 wheel drive
pic's
the car after 2 years off daily driver.
first gearbox fitting :
and now cutting the chassis
little 3d for the front coil over
here the steel part for the news hybride drive shaft i'ts a mix of rear wrx shaft and front STI hub...
future new parts 28mm diameter
pic's of the week end :
now i'm waiting for rear coilover and i need to finalize 3d for the front arms and coilover setup
www.flat4parts.com
Old January 17th 2011, 06:47
MX67 MX67 is offline
It looks very interesting!
Front diff is from WRX also?
You've flipped the diff in the gearbox without problems?
What is the weight of the engine/transmission/front diff?
Keep it going! Cool ride
1967 Bug
Old January 17th 2011, 07:59
F4P's Avatar
F4P F4P is offline
yes front diff from wrx it was flipped upside down for the gearbox i have to bought the reversion kit
www.flat4parts.com
Old January 17th 2011, 08:44
Cant wait to see more of this, well done.
Old January 17th 2011, 09:48
An AWD 1303 with WRX drivetrain. Now that should be fun. I will be watching this build. Keep the updates rolling in.
Old January 17th 2011, 13:29
Very interesting project! Where did you buy the gearbox conversion kit for use as a rear engine? How much did it cost?
Old January 17th 2011, 15:21
F4P's Avatar
F4P F4P is offline
you can find parts here http://www.subarugears.com/
www.flat4parts.com
Old January 19th 2011, 00:29
Really really cool, great idea, I didn't know the parts existed for the reverse gear set, keep it up!
Old January 19th 2011, 03:17
chug_A_bug's Avatar
WOW you are making my Dream come true.... I have been Dreaming for years to build one just no Space and $$ to Do something like this, Keep up the good work man
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 19th 2011, 04:30
judgie's Avatar
judgie judgie is offline
been wiating for someone to try this since the flip kit came on the market. will be watching this with intrest.
Old January 20th 2011, 20:37
onixbonilla's Avatar
onixbonilla onixbonilla is offline
I bet a lot of us had dreamed of this before! Been owner of a 2004 STI and 2008 Legacy I can attest the 4WD virtues! Will follow from begining to finish! Also noted that you have a rising custom VW parts bussiness, maybe from your learning you can bring to the market some parts to made this conversion easier!!!
Old January 21st 2011, 04:30
F4P's Avatar
F4P F4P is offline
news ..
making asm for simultaion of front drive..
the problem is the insert struts was too long.. i need shorter one..
if any body have an idea in wich car i can find short insert struts ....
http://www.youtube.com/v/-rkNgPUHChA
www.flat4parts.com
Old January 21st 2011, 04:41
superb superb is offline
I'm not 100% but I thought that the subbies favored the rear wheels, which now is the front. I think its going to be a front bias system
'74 super, chooped 2.5 inches, going to attempt to make a a-arm rear suspension and run a turbo 2.0 with sds
Old January 21st 2011, 05:20
Birdman69 Birdman69 is offline
A centre diff controller should fix that. But i'm not sure how much power that will allow you to send to the front (now rear) diff, a 50/50 split may be all it would give?
AWDVW Awesome!
I plan on using one of the reverse cut ring and pinions in a sti 5 speed box in my 69. Sti powered offcourse
Old January 24th 2011, 03:22
F4P's Avatar
F4P F4P is offline
hello if i'm right the subby was 48-52 or 50-50 front rear .. so i'ts ok for me
pics of the weekend :
i have to cut here for the driveshaft
www.flat4parts.com
