Old April 10th 2010, 19:03
supie supie is offline
Unhappy German look Parts. Splitting project
spiltting up my german look project. can supply photos by e-mail as required.. Located in St Albans , Hertfordshire.
If in doubt try me on an offer! No sensible offer refused.
1302 shell, converted to r/h/d with steel sliding sunroof. Comes with sunroof, Bonnet doors decklid. in primer. Requires a day or so for paint. No rot or rust. Best you will find.£800 also includes whatever you need from donor car FREE OF CHARGE. If you can carry it , you can have it. Cannot say fairer.
2x Porsche 944 turbo front spindles Late model.£150 pr
2x 911 gearbox drive flanges.£80 pr
2x 996 gt3 floating discs. Used but still plenty of life left.£100pr
944 turbo L/H and R/H ALLOY Rear trailing arms with output flanges and urethane bushes already fitted. Bead blasted.bolt straight on 1302/1303 Requires new wheel bearings.£300 pr
2x 944 turbo front dampers.Used but servicable.£80 pair
L.A Performance J-Tubes for 914/T4 oval port heads.£80
2x Porsche 944 turbo hubs.£180pr
1303 lower front suspension arms.Stripped and require painting and bushes.£40pr
2x T4 oil pumps both good condition.£10 ea
2x 914 foglamp brackets. £20
front and rear 914 bumper over riders.£40pr
Porsche 914 Air mass meter with air box. 1.8 works perfectly.£100
Porsche 914 Crankshaft. Std size.Porsche Conrods x4 Ready to fit.£200
porsche used brake pad sets. still over 50% of material left. For 6 po and 4 pot apps. 996, 993 964 calipers.£15 set
1500 window rubber set.Never fitted. £30
any more info please e-mail me at drsupie AT hotmail.com or cal 07834775628.
cheers Dafyd.
