Old September 12th 2010, 14:18
Fast65 Fast65 is offline
My 65
my cars not german look or Cal Look but has bits of both some of you may have seen my car on other forums so fingers crossed not to boring lol
Specs so far
Engine
2332 turbo, efi, NOS, water injected, charge cooled T1
Transmission
T1 pro street
Wheels
OG Bruners
Brakes
944 Turbo with 928 4 pots
Interior
70s 911 tombstones and a few gauges
ive done all the work on the car myself starting from this
Ok i purchased this bug for my wife in 2007 and looked like this
i wanted her to stay like this but claire wanted me to lower her so she then looked like this
so that was it the car has been messed with so i took this out
and put this in
2332cc CB high roof case, Scat crank 84mm, CB H beam rods, 94mm B+P, Total seal rings, Engle FK10 cam, Scat lifters, Berg chromoly pushrods, Jaycee pushrod tubes, Scat 1.4 rockers, A1 1 3/4 Sidewinder exhaust ceramic header and stainless back box Vband clamp , Deep sump, Jeff Denham welded heads 44 x 37 valves heavily reworked with matching manifolds, Berg linkage, Fuel injection kit-CB throttle bodies, DTA .
Gearbox by Cogbox close 1,2 and 3 gears tall 4th for cruising all welded gears heavy duty side plate, superdiff Sway away short race axles.
then to stop i made these fit
so all is going well then i find loads of the ginger stuff bottom of door, some in the wings and heater channels. I found some NOS 65 doors and got hold of some day mouldings wings and painted them then started on the channels
now looks like this
im fitting a G50 over the winter so watch this space
cheers andy
Old September 12th 2010, 20:31
Very cool, and a nice story too!
You must be a plumber considering all the hoses and fittings you have to deal with!!!
Awesome.
Old September 13th 2010, 09:19
vdubfund's Avatar
vdubfund vdubfund is offline
Fast65
Looks great!
Just a few question. How is the turning with the calipers sitting on the front side of the wheel? Any hitting the torsion arms?
Did you weld a 944 spindle to a CB spindle? Are those 86 T brakes? Narrowed beam?
I'm in the process of doing something very similar to my 64.
Nice work!
Old September 13th 2010, 11:46
effvee effvee is offline
Oil Tank?
Hi, is that a oil tank behind your rear seat? If so, is it vented to the inside also?
Old September 13th 2010, 13:13
hi yes it is an oil tank it does vent out side, the breather was put there so i didnt loose it lol
cheers andy
Old September 13th 2010, 13:17
Originally Posted by vdubfund View Post
Fast65
Looks great!
No problems at all
none all fine
yes and it is also bolted i have had the welds have been crack tested
yes they are
Narrowed beam?
yes 4"
there is also a bit of work to get the rears to fit they dont dont straight on
Nice work!
Cheers thanks
hope that help cheers andy
Old September 13th 2010, 22:31
What a transformation, well done.
Are you using the A1 headers with your turbo?
Old September 14th 2010, 03:40
thanks, yes im using an a1 header
cheers andy
Old September 14th 2010, 08:53
That would make it much nicer off boost, do you have any photos of the turbo pipe work after the A1s?
Old September 14th 2010, 13:00
hi yes
and the inlet
got to change alot of it now as the turbo oil seals failed
cheers andy
Old September 14th 2010, 13:22
old holset off and thers still oil coming out another pint
the two together
holset is the top one, T4 is the bottom one the T4 has a smaller exhaust and larger compressor wooo
turbo trial mounted it all looked good until I tried the wheel know its all got to move now but not sure were yet maybe under the boot floor
but thats for tmw
cheers andy
Old September 14th 2010, 16:35
Humble's Avatar
Humble Humble is offline
Awesome project, I'd love to see some hp numbers
You run out of room quick when you add a turbo, but I do like the way the A1 setup looks. I don't think there's enough room on my car to mount the turbo there.
Old September 14th 2010, 17:04
cheers thanks i cant wait to get some numbers i would love to get 400hp, and yes you soon run out of room
oil cooler here
look what i did to fit a water injection tank
and ive hidden the pump under the feul tank
cheers andy
Old September 20th 2010, 15:03
its in just got make the muffler fit and sort the idle think ive got an air leak
cheers andy
Old September 20th 2010, 17:29
Love how you integrated the water tank, but wouldn't you have gained a lot more volume by putting the filler at the top?
