Old July 25th 2012, 05:18
Spark Plugs
Which spark plugs do you use? Especially in hi-po engines.
Different head range affects engine performance?
Thanks.
T4 2666 1303s
Old July 27th 2012, 10:39
i use an nkg bps 7 its a heat range or two higher than stock as mine is a turbo aircooled
Old July 29th 2012, 20:15
Thanks for the reply, as my friend"s 2165 had problems when used stock plugs, he changed to ngk 7, no problems. Its does affect does it!
T4 2666 1303s
