Old March 3rd 2014, 23:33
effvee effvee is offline
Air Cooled Engne Oils
Hi, I've read where there is a special oil for the seats/guided for the air cooled engine. Can some confirm this? Am I to understand the Castro oils and Havoline, Quarker State oil won't supply the needed lubrication?
Old March 4th 2014, 13:54
Humble's Avatar
Humble Humble is offline
I generally run bradpenn, royal purple, or royal purple max cycle motorcycle oil ($$$). There's also different additives from archoil or nanolube but I haven't had a chance to run those yet, though I do use archoil tungsten-disulphide grease in my assembly lube recipe.
Old March 4th 2014, 22:48
Joe Gibbs make a great oil also. ANY engine that runs a flat tappet cam (non roller) you need zinc or ZDDP (zinc dialkyl dithio phosphate) to keep the lifters and cam lobes from wearing out too fast.
Old March 6th 2014, 13:32
I've used the Brad Penn "Green Oil" for years, but have heard good things about the Joe Gibbs "Driven" oil. Some good reading -- http://lnengineering.com/resources/2...ut-motor-oils/
Kafer_Mike
Old March 6th 2014, 18:14
How much per quart? How about having your cam hardened.
Old March 7th 2014, 11:00
Brad Penn is usually around $6-7 a quart in the parts stores/race shops. I get it thru a local oil distributor for $61 per case retail; ~$5 a quart. I'm running a standard Engle FK47 and SLR-treated German lifters. No issues.
Kafer_Mike
