Old August 27th 2002, 10:50
DORIGTT's Avatar
DORIGTT DORIGTT is offline
How much do 944T brakes move the wheel out?
I understand that the 944 brake conversion when done on a balljoint front suspension and the IRS rear will widen the track.
How much does the track width increase?
Old August 27th 2002, 10:55
It depends on several factors.
Usin steel trailing arms at rear you will have a 25mm increase perside, add an inch perside if you also use hte Aluminium trailing arms.
The front varies as there are quite a few different methods using early or late style hubs. I think mine was increased by no more than 10mm with bearing adapters, but I haven't measured.
Rich
