Old October 4th 2003, 11:15
Dells are done
Well the $200 Dells are done. I just need to pick up the throttle stop arm at Zen's today and put it on. Also need to calibrate the Accel. pump squirt. I took pix along the way to write a Tech Article.
Before
Old October 4th 2003, 11:16
I still need to get the NOS holes in the intakes TIG welded and smothed out.
After
Old October 4th 2003, 13:25
craazy Cooter's Avatar
Where did you buy your dells? I got a pair of euro model 36mms
with the little choke valve on the back from the alfa dude on ebay
for $140. And a empi carb kit sans carbs for 100. Nice linkage,
all parts brand new.
Old October 4th 2003, 20:46
I bought them at The Southeastern Bug Fair in Toccoa GA.(swap meet). Carbs(45 DRLA's), intakes, linkage and 2 CB master rebuild kits for $200. Had to order a throttle stop arm and return spring for the right side.
I just tried to put the spring and arm on and CB sent me the wrong spring. I just emailed them to see if they will send me the right one.
