Old August 8th 2003, 03:01
63Rag 63Rag is offline
63 body on 69 and late pan?
Ive bought porsche C2 brakes and im in the process of getting 944 turbo trailing arms. Quistion I is there major surgery with swapping placing a 1963 body on to a 69 and later pan. Advantage ball joint etc. etc.
thanks for your response.
Wolf
Old August 8th 2003, 07:59
vujade's Avatar
vujade vujade is offline
from my understanding it is a pretty straight forward swap
WinterJam 2010
Old August 8th 2003, 12:03
bugsoup bugsoup is offline
I am putting a 56 body onto a 69 pan and the only significant problem I have to deal with is the rear mount on the body. Its a small bracket that bolts the body to the shock tower and need to be relocated by about 2 inches. The bracket is only spot welded to the body, so moving it should not be hard. I'm not sure what year VW changed the position of this, but you may not need to do this for your 63 body. Someone else may have the definitive answer and a way to tell before triall fitting. Hope this helps.
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old January 21st 2004, 19:42
Dasdubber's Avatar
Here is a link to an aussie vw forum site (I am from Australia) which details my mods to the rear body mount when I put my 63 body onto a 68 swing axle pan...
http://www.aussieveedubbers.com/foru...d.php?tid=8392
Alan
Old January 22nd 2004, 00:47
My suggestion would be just to cut the bottom out of the bracket, narrow it, cut off the length on the bottom of the vertical portion of the bracket, then weld the bottom back on again aftet the correct level is achieved. Remember, there is supposed to be a rubber mount in between the 2
http://motorworks.com/search2_descri...O=111+899+119B
While your at it, you might just want to seam weld the rest of the bracket to the body too.
