Old December 23rd 2004, 10:43
944 brake conversion parts list
haha. not the answers you were seeking, but hopefully will be soon. i am willing to pull together a matrix of parts options and lists by model if those people that have the info can throw it in here. my guess without thinking through this much yet is spreadsheet format of options down the side and applicable car models across the top. i wonder if this is even doable. so i.e., i have a standard and can list one option of 951 stuff on late arms. the options will pretty much be limitless as i used 911 carrera rotors on the front. probably much different than most, but the rest of my build was the same.
anyway, let's give it a try. those that have done their conversion, throw out some part numbers and part number range if you know it (super, maybe you can be a help here since you seem to be the master at part numbers) and details on the options. i will see if i can get it into a readable format.
Old December 23rd 2004, 17:09
Superman
I've already put up a list at the link below, although it's not a list per person per their car... but it is a 944 parts number list.
http://www.germanlook.com/Html/Tech/...artNumbers.htm
Old December 23rd 2004, 17:11
Superman
Not a master, I just have the book to look them up
Old December 25th 2004, 15:01
flat flat is offline
Superman,
I have to tell you that you list has been very useful to me. Thanx.
How about adding more info; brake rotor sizes, caliper piston sizes etc? I'd be glad to help.
Easy,
www.vdubengineering.com
Old December 26th 2004, 06:19
Superman
Good idea, I have the info and will add it ASAP
Old December 29th 2004, 13:41
MattKab's Avatar
MattKab MattKab is offline
That's a great idea, such info was all but impossible to find 2.5 years ago
Matt
