Old October 13th 2004, 12:00
Bill K.'s Avatar
Bill K. Bill K. is offline
Metal valve stems
I'm ready to mount and balance tires on my 16x6 and 16x7 Fuchs and want to have robust valve stems that won't leak at high speed or fail over time.
I'll get the Porsche crested caps with the o-ring in them to prevent the schrader valve from leaking at high speed. I've seen the stock rubber Porsche valve stems with the metal sleeve and the valve stem supports.
Picture from EagleDay.com
But I've read on the Pelican forum that metal stems are preferred.
Please share your experience with/knowledge of metal valve stems.
Old October 13th 2004, 19:52
Superman
It is my opinion that with our cars' speed capacity there wouldn't be a problem with the use of any valve stem. If you under/over tighten the closure of the nut on the metal ones they'll leak. Some have used the rubber stems with the metal covers (as in your picture). Valve stems are like belt buckles, it's to your taste; well unless you have an F1 racer or something then it would really matter because of the centrificul force. My personal taste is the full metal ones that bolt to the wheel.
Old October 13th 2004, 22:33
boygenius's Avatar
My bike has rubber valve stems and it goes 190mph... I like the look of the rubber stems in my rims with the aluminum covers on them. They almost dissapear into the rim.
Old October 13th 2004, 22:53
Bill K.'s Avatar
Thanks Superman, but I don't wear belts -- I'm into the CrackLook...
Boygenius -- Do the aluminum Porsche OEM ones pictured above have a rigid feel like the all metal ones? Or do they tweek over when you push on them? The 6" wheels don't have room for the support piece like the 7's do.
What size hole is in a Fuchs wheel? Does anyone have an online source for all aluminum stems? I don't want to put any chrome on the car
Old October 13th 2004, 23:47
boygenius's Avatar
Mine wiggle just like normal rubber ones do but the stem is recessed into the rim so mine can only push over about 3/16".
Old October 14th 2004, 00:30
Superman
The holes are an industry standard, they are all the same regardless of manufactuer. I don't wear belts either except with my uniform.
Old October 14th 2004, 00:32
Superman
Never had them (OEM Porsche) ones in my cars but have seen them on cars before, so I can't really answer that one. The non-Porsche ones I have held don't seem too strong or at least not as strong as the solid metal kind. They are just thin covers.
Old January 4th 2005, 00:50
GRMNLK's Avatar
GRMNLK GRMNLK is offline
What do your fuchs look like? are they powder coated?
I work with tires and valve stems, I think if you put a short black stem with a porsche cap it would look fine.
Old January 4th 2005, 01:32
Bill K.'s Avatar
The Porsche stem covering caps are a good choice to blend into the anodized lips of the Fuchs. I wanted a stem that doesn't deflect when using air line/gauge so I went with Ferrari stems per Weidman's (wheel refinisher) recommendations. They are aluminum and blend in nice. Wheels are refinished with painted centers and anodized lips. This is the 16x7 on the rear. The 16x6 on the front has a tighter fit for the base of the stem, but Weidman made it work.
Old January 4th 2005, 16:46
GRMNLK's Avatar
I guess a black stem would not be the best choice for your set up. The bolt ins blend in good with the rest of the wheel...I like the center color!!
Old January 4th 2005, 18:51
MattKab's Avatar
MattKab MattKab is offline
That's a nice wheel!
What is the name of that blue (If you don't mind telling)? It's stunning.
Matt
Old January 4th 2005, 19:09
Bill K.'s Avatar
Thanks. I'm glad I went this route. The color is Porsche Lapis Blue Metallic (2004). Check out your local Porsche dealer. It morphs from purple in the light to dark blue in the shade.
Old January 5th 2005, 14:27
MattKab's Avatar
Thanks Bill, a mate has an '04 996 that colour. The camera sure brings out the best, good choice.
Matt
Old January 13th 2005, 23:33
Pillow's Avatar
Pillow Pillow is offline
Nice ride Bill!
The wheels fit perfectly with the offset!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
