Old March 12th 2005, 16:03
Troy_Audio's Avatar
How to Set Brake/Clutch Ride hight?
Hey,Guys
I just installed new pedals in my 65..
My problem is they sit low or should i say hang..
How do i raze them? I ajusted everthing so it ingauges in the place i need but how can get them to stay up inplace?
>>MORE PIX<<
Thanks Guys
Troy
Old May 16th 2005, 22:14
LLVWGL LLVWGL is offline
there is a little metal tab that should be just in FRONT of the pedal cluster. what you have to do is loosen the cluster (possibly remove the FRONT bolt) and hold the pedals up while you tighten the bolts back down.
There are also tabs on the pedals which catch on the tab on the floorpan.
does this help?
and if you have adjusted the clutch cable/master cylinder pushrod to accomidate that pedal setup you will have to re-adjust them for the correct locations.
Old May 17th 2005, 23:13
Troy_Audio's Avatar
Thanks I just got them Set ...
Now Im putting a Duel Stage Master in..lol
Guess I will do it again..lol
Peace Troy
