Old September 7th 2005, 22:44
flat flat is offline
Kafer bars..Almost ready
I've been talking about making my version of the Kafer bar. Here are some pics of how it's coming along. Almost there. I'll be ready to fully market it in 6-8 weeks. Introductory price of only $C260 (about $US220) for the 3 bar. Stainless tubes can be custom ordered at a premium of about $C30 for the 3-bar. 5-bar's and super strut bars using the same clevis style are also coming up.
The clevis pictures are not finished, still have to mill the groove and hole for the screw.
www.vdubengineering.com
Old September 21st 2005, 21:46
LLVWGL LLVWGL is offline
interested. . . .
are the ends really finely threaded, or are there threads at all?
Old September 21st 2005, 22:29
Yes, they are threaded with a metric extra fine thread pitch. Jam nuts will be included to set the length. I'll post more pics as I have the parts ready.
Old September 22nd 2005, 18:13
Doogie S's Avatar
Doogie S Doogie S is offline
Lanner,
Sign me up for one. I'd like the 5 bar set-up though.
Have you test fit the set-up on a Ghia? I would assume that the clearances will be the same as a beetle, but I've been supprised before.
Cheers,
Doug
Old September 23rd 2005, 02:21
ditto on the 5 bar.
2 more questions:
Are the brackets for the ends of the framehorns going to be weld-on or bolt on?
And are the FRONT brackets for the five bar going to be made out of steel to weld on?
Old September 23rd 2005, 09:48
The only way to insure perfect fit for each application withourtcompromises is to let the end user set up the frame horn brackets, hence they will be weld on, and made out of steel. The same applies to the 5 bar front brackets.
My biggest hurdle is the end pieces, they are still at the CNC shop and delivery keeps getting pushed back. I'll keep you guys posted.
As for test fitting on a KG, I haven't done it yet. I know that the 73+ T1's (beetle ang ghia) require quite a bit of trimming near the shock mount because the inner fender panels are double walled whearas the earlier cars are all single walled.
Old September 28th 2005, 08:04
Bad bug's Avatar
Bad bug Bad bug is offline
I would realy love a five bar setup for my beetle as i am thinking of converting my swing axle car to irs rear end.
Old October 2nd 2005, 13:27
Hold tight guys, I'll probably have something ready within 10-14 days.
Old October 4th 2005, 14:34
Doogie S's Avatar
Right-on!
Just in time for Christmas. (do you hear that honey?)
Cheers,
Doug
Old October 5th 2005, 21:22
Booyaah!
They're done. Designed and manufactured in Canada. Keep the dollar on this side of the pacific!
VdubCustoms has designed and manufactured this kafer cup bar to provide the maximum amount of chassis stiffness. Manufactured from aircraft grade aluminum, the clevis ends and tubes are exactlingly machined. All metric grade high-strength hardware provided. Laser cut mounting plates require welding to fit to your chassis. Not bolt on.
Promotional price:
3 bar setup $C265. ($US225)
5 bar setup $C375. ($US320)
lanner@vdubcustoms.com
Old October 5th 2005, 21:35
LOAF's Avatar
LOAF LOAF is offline
Nice..
I know what I want for my birthday.. excellent job..
also a
Old October 5th 2005, 23:09
Mikey's Avatar
Mikey Mikey is offline
Email sent.. I hope to have one real soon.
Mike
'04 R32 Tornado Red
Old October 6th 2005, 14:53
Doogie S's Avatar
Lanner,
email sent requesting shipping cost on 5 bar set-up.
Cheers,
DOug
Old October 7th 2005, 04:06
So. . . . .where it mounts to the upper shock mount is weld-on? don't you think people will run into problems trying to weld onto the cast steel? (I have heard that it is very difficult to weld onto.)
Old October 7th 2005, 21:37
Mikey's Avatar
They don't weld to the shock mount. You just weld to a small peice, then add a longer shock bolt...
(nut)[spacer]{shock}|mount|[]
Crude but effective... The spacer is what you weld to, My guess is get it all in position with the shock. Tack it, then put it away from the shock to weld, that way the rubber part of the shock doesn't heat up. Probably use a pair of vise grips to hold the tab into position. Mig would be the best process to use. (Vs stick, tig, or Flux core) Am I getting too detailed?
That's just the way I see it though.
Mike
'04 R32 Tornado Red
