Old May 1st 2006, 10:55
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Hey Sandeep
Hiya Sandeep,
I noticed that you have a set of those snappy whiteline sway bars. I need to buy a front one for my Ghia as I only have a rear one and its a tail happy turbo beast.
I see you got yours from aircooled.net. 20mm front and 24mm back, I am thinking 22mm front and 27mm back for my ghia because its a bit heavier than yours. I will be running bilstein yellow shocks, CB drop spindles and stock beam
What do you think?
Thanks,bry
GL ghia restoration:
Old May 1st 2006, 11:53
Bryan,
I have the 20mm street adjustable front bar and the 24mm street adjustable rear bar. I didn't go with the race adjustable on the rear because I have a Cup brace that stiffens the rear a bit already.
Got then from Aircooled.net .... you could also give JRP a call and see if you can get them locally as they stock Whiteline bars for subaru's.
