Old May 11th 2006, 23:29
LLVWGL LLVWGL is offline
sucessfull CRX "coil over" use.
Has anyone sucessfully used a Crx or honda aftermarket spring in place of a Maxx Strut? I am very close to installing my porsche Cup II's and 944NA brakes, and I am fiddling with crx springs on my 1302. However, I am running into problems. If someone could post a picture of their sucessfull conversion that would help immensly.
Thanks,
Nick
Old May 12th 2006, 10:17
petevw's Avatar
petevw petevw is offline
I'll try to take some pics this weekend. What problems are you having?
'72 super
'65 bus
'52 split
Old May 12th 2006, 13:36
Bullyboy Bullyboy is offline
Vdubengineering.com
they have a kit
Old May 12th 2006, 20:43
petevw's Avatar
^^^Yup, Lanner helped me out with mine.
'72 super
'65 bus
'52 split
Old May 14th 2006, 02:57
Well, I am trying to utilize the adjust-a-struts that I already have, and I am unable to fit the threaded sleeve that came with my "coil-over" kit onto the strut housing (Diameter of sleeve too small).
So what I have together thus far is the Adjust-a-strut with the bottom spring perch cut off (leaving just a small sleeve on the strut housing) that the New spring perch (Al, from the coil over kit) rests on then the spring, top perch and top bearing.
The problem is that with the strut adjusted as high as possible, the strut assembly is too short, making the car too low for my cup IIs.
- What I really need to see is if people have used the generic coil over kits like the one I have, AND if they used a stock strut housing, or an adjust-a-strut as a base for the conversion.
My other option is to use the STOCK strut housings and shorten them to use a MK1 Golf strut insert (like the adjust a struts) then use the aluminum threaded sleeves that came with the "coil over" kit for adjustability. I am able to use the sleeves in this instance because the stock struts have a smaller diameter housing.
The main goal of this headache is to have a height/corner weight adjustable front suspension with a readily availabe variety of different stiffness springs, and not pay $500 for something I can make.
Old May 16th 2006, 10:03
PJL54Oval PJL54Oval is offline
If you can get a better ride than my Maxx strutts I'm all for it!
Old May 16th 2006, 21:26
Anyone. . . . .? Does anyone have an idea where I can find pics of this type of modification?
Old May 17th 2006, 00:31
petevw's Avatar
I used parts from the factory rear struts. Taking it apart you are going to use the spring, rubber spring cups (which are at the top), and the spring perch, which separates from the factory strut at the bottom of the spring.
So now, with these 3 parts, place the rubber ring, on the bottom adjust-a-strut perch. The metal bottom perch now will become your top perch. You weld this to the beetle top spring plate/retainer. You can weld this on a offset biased to the middle of the car for more tire clearance. You have to make sure everything is clear for the damper rod to pass through.
hope this is clear.
I'll try to get under the car tommorrow for some pics.
'72 super
'65 bus
'52 split
Old May 18th 2006, 02:01
Oh, i see. It sounds like you used stock rear CRX parts, and I thought I could get away with using one of these kits.
perhaps I should just purchase a taller set of springs.
Pics would be GREATLY appreciated!
Thanks,
Nick
