Old March 15th 2007, 10:03
kafercup55 kafercup55 is offline
What size axles should I run?
I'm coming from the watercooled VW scene and building a German-looker that's more performance than look, and I have a quick question re: axle sizing.
The car is a 77 standard with a completely rebuilt IRS chassis. I have a KCR ProStreet Tranny on the way, and CB Performance disc brakes on all 4 corners. The wheels will be RH ZW1's in a 17x8 and 17x10 setup with an ET of 35 after adapters are used. What size axles should I use here? I'm not worried about the wheels because I already have to replace the stock fenders with a fiberglass set.
Thanks for any help you could provide.
Old March 15th 2007, 11:45
The strongest CV's are the Porsche 930's. If your not gonna "hole shot it" or do burnouts, then T2 CV's will work. For axle's, sway away makes custom ones, and EMPI (not sure about quality on EMPI though). If it is to be drag raced "swing axle" is your best bet.
Old March 15th 2007, 12:45
Great info...thank you. Any idea of what length I should use?
Old March 15th 2007, 18:58
yetibone's Avatar
yetibone yetibone is offline
If your control arms are stock, or non-turbo, pre-'86 944 parts, then stock length will be what you need.
If you're using alloy 944S, 951, or 968 control arms, use '87 and later 944S axles.
The 944 turbo axles are the right length, but have the wrong splines.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old March 15th 2007, 23:34
Please excuse my french, but **** The Samba... this place is great.
Thx to you guys with your great answers. Just what I was looking for and then some. :agree:
-T
