Old October 10th 2006, 00:26
Bullyboy Bullyboy is offline
Who is running 15x7 fronts?
I have a set of 15x7 et52.5mm phone dials with a 2" narrowed BJ beam with a 2-3" drop, 944N/A front disks on my 61'beetle with a 69' IRS pan.
Just wondering if anyone is running something similar, and tire size experiences.
Thanks Mark
Old October 13th 2006, 00:16
So nobody has 15x7"s on the front?
Old October 13th 2006, 09:12
flat flat is offline
I've never run that particular combo, but I know a 7"et42 on a 3" beam tucks stock fenders, and on a 2" beam it just fits. You will probably need spacers to get the deeper offset wheels away from the lower control arm so you have a decent turn capabilities.
www.vdubengineering.com
Old October 13th 2006, 09:19
bow's Avatar
bow bow is offline
yes im runnin that combomy tires rub they kinda stick out about an inch
YEAH ITS GOT A HEMI
Old October 13th 2006, 15:46
Mikey's Avatar
Mikey Mikey is offline
Flat is right, I have a set of cookies. I stuck them on my Ghia just for kicks and they catch the lower ball joint. Almost sit on it. Stock beam, with lowered spindles. I had to buy a 16" or larger spare because the 15" inflate-a-spare did the same thing.
Mike
'04 R32 Tornado Red
Old October 13th 2006, 17:01
I know I'm okay as far as clearance to suspension and the fenders. I just need to finish assembly on my steering so I can find out how little steering I have nothing like waiting for parts..... again
Looks like I'll have to invest in some spacers and longer studs.
Old March 6th 2007, 14:52
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
How about an update & maybe a pic?
I'm waiting on my 15x7 phonedials to show. They are going on a '74 Standard.
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
Old March 7th 2007, 17:49
Rob's Avatar
Rob Rob is offline
I'm running 15x6.5 on a '70 Standard.
I'm using a spacer, but my turning radius still sucks.
Rob.
Old March 8th 2007, 09:44
OldeFahrt's Avatar
What's your offset? Got a pic showing the fender too? Just to see how it fits.
Old March 8th 2007, 10:01
Rob's Avatar
Rob Rob is offline
Front Fender:
I'm not really happy how they fit. I was planning on using the car for autoX, but it now has the turning radius of a Semi
Should have done more research up front.
Eventually I might have to go with a narrowed beam, and even bigger spacers...
I *think* the offset is either +35 or +38, I'd need to measure to be sure.
Rob.
Old March 8th 2007, 10:05
OldeFahrt's Avatar
Rob.
Where does it rub? The trailing arms or fender?
Old April 27th 2007, 13:34
Veedub Veedub is offline
Front Fender:
Rob.
That sucks, kinda reminds me of my bug.Mine stick out like that, sad thing is there 15x4.5" but I think what makes mine l;ook like that is the 195/60 on my wheel.It looks just like that, looking at your picture above. wonder how my turning will be...
Old April 27th 2007, 15:27
I have 195/55-15 on 15x7 et52.5
25mm spacer(washers right now ), 2" narrowed beam
still waiting for my body to get back from the body shop for final assembly
Old April 28th 2007, 11:14
Rob's Avatar
Rob Rob is offline
The tire actually hits the framehead.
Rob.
Old May 3rd 2007, 21:58
73notch's Avatar
73notch 73notch is offline
Rob.
You can get some narrower tires, and that will allow it to clear. Not sure what size you are running, but if they were 8s, i would recommend a 195/50 or 45.
www.subynotch.com
