Old May 28th 2007, 20:42
yetibone's Avatar
yetibone yetibone is offline
Final assembly.
Some pics. I painted the interior, jambs, and front and rear compartments Porsche Iris blue (L39V) here at home, then dropped the body back onto the pan for the last time. After assembling the front suspension, I hauled it to a friend's shop for the exterior paint. I've been working on wiring for 2 weeks, and finally got it sorted, gauges working, and lights burning. I still have to add a fuse holder for the driving lights, and fuel pump.
Made the muffler mounting today from BMW tranny mounts, and aluminum straps.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 28th 2007, 20:47
yetibone's Avatar
One more... This shows the aluminum mounting plate for the coil, ballast resistor, and fuel pressure regulator, and a pic from the front.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 29th 2007, 18:36
vujade's Avatar
vujade vujade is offline
nice work man :agree:
WinterJam 2010
Old May 29th 2007, 19:00
yetibone's Avatar
Thanks. It feels good to finally see how it's going to really look with the color.
Makes me feel stoked about building this car again.
I'm waiting for my friend at the body shop to fix a couple of maximum flow indicators that ended up on the drivers side fenders, but other than that, the finish is done.
I'm still a ways out from being finished. I think the car needs to be about an inch lower in the rear, and a half inch in front. I also have to open the engine back up and install the right oil pump pickup tube for a GE case.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 29th 2007, 21:06
yellow73's Avatar
yellow73 yellow73 is offline
Yeti,
Thanks for the updates. Your car looks great, I am looking forward to seeing it.
73 Type 1 - 2270 Type IV
64 Type 34 - 1500 Type III
Old May 30th 2007, 06:27
1303R's Avatar
1303R 1303R is offline
how nice is that gonna look! what are these maximum flow indicators? good job
Old May 30th 2007, 12:22
yetibone's Avatar
Runs in the clear coat.
I ended up with some maximum depth indicators (trash under the clearcoat) under the front decklid, but I'm not worried.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 30th 2007, 22:05
Nice work. I love the dash.:agree:
Old May 31st 2007, 20:05
yetibone's Avatar
Should be the crowning component of the interior 'cause I don't think there'll be much else besides the seats, shifter, pedals, and that.
Wiring all those dash lights, and gauges was a bonafide nightmare because I retained all the factory vent and defrost ductwork. Made it pretty tight back in there. I also had to lengthen a few wires, which I soldered, and insulated with heat shrink tubing.
If I'm done by Sept, I'll drive it to Taccoa fer sure.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 1st 2007, 14:56
very cool to see you getting in the stretch. i think we are all looking forward to seeing it. one more GL on the road.
Old June 2nd 2007, 18:43
yetibone's Avatar
Sweet mercy, can't you just see my genuine excitement over all this...
Really though, I can't stop working on it. The only reason I posted this is cause I had to come inside and eat a sammich before I passed out!
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 2nd 2007, 19:17
That shot belongs on a CD cover.
Old June 2nd 2007, 19:44
yetibone's Avatar
I know, right? Too bad Joe's Garage was taken.
I posted a better one on The Samba...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old June 3rd 2007, 18:02
trevorbrady's Avatar
trevorbrady trevorbrady is offline
hey Yetibone, your car looks great, well done!
those are early aluminium rear trailing arms, right? and Boxster wheels? The offset on those rear wheels is ET50mm right? How much wider than stock are the rear wings (fenders) you have on?
thanks and best of luck with the finish
Old June 3rd 2007, 18:09
yetibone's Avatar
That's right.
I have 38mm spacers, and the fenders are 76mm wider on each side. With the late 951 arms, you would have very close to the same look, without the spacers.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
