Old July 25th 2002, 22:28
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Fitments for my Ghia Coupe
Which offsets should I use on my 1970 Ghia Coupe? I plan to use 944T brakes front and rear and would like to use 17x7 front and 17x8 rear. I know I have to 'slightly' modify/roll my fender lips in the rear so that's no problem.
Old July 26th 2002, 10:48
Oliver Knuf's Avatar
rims...
8" on the rear??
You have to slightly roll a Ghia with normal 8-spokes in the rear (I had that a few weeks ago with 5,5x15 with an offset of (German measuring ET) 40mm), 8" is a horror. Make your rear smaller, no, bad solution. Weld on a bit to the fender lips... ???!!?!! Also bad...
Click here to mail me!
Old July 26th 2002, 17:39
DORIGTT's Avatar
How can I send you a picture of some?
Oliver,
I've got a series of pics of Ghias with obviously stock bodywork and Porsche Cup II wheels on them as well as Porsche brake systems.
How can I send you some pics for you to look at
Old December 8th 2005, 23:16
blackdoggriffon's Avatar
blackdoggriffon blackdoggriffon is offline
Originally Posted by DORIGTT
Oliver,
Could you please send me those pics? I am thinking of fitting Cup II wheels to my 1960 vert.
Old December 8th 2005, 23:38
Mikey's Avatar
Mikey Mikey is offline
I think the Cup II's are popular with Ghias.
I'm putting a set on of Cup II's on my Ghia now. I've got a whole set of 17" x 7's ET55. They all fit good. I'm going to try to stuff either a 9" rear or a pair of 8". I won't know what will be required untill I get the wheels. I've got a 2in narrowed/adjustable beam and drop spindles. I'm thinking of .5" spacers on each side to move the wheels back out. Since they hit the inner fenders bad. (I have pictures, but they're too big to post. )
Mike
'04 R32 Tornado Red
Old December 10th 2005, 12:08
70Ghia 70Ghia is offline
Mike,
Here are some pics of my Cup II's, they are stock 17 x 7 boxsters. I tried giving you some idea of the space.
Chris
Old December 10th 2005, 12:33
Mikey's Avatar
Thanks for the pictures, your Ghia looks Awesome. :righton:
It looks like a lot of room on the inside, but I'll probably run into the spring plate before I hit the inner fender. And if I decide to run Porsche brakes, I'll have to either narrow my trailing arms or buy some. (If I can't narrow them enough.) I measured my Ghia too. That's why I think I can fit 9's in the back. For them Not to fit, they'd have to hit both the spring plate and the fender lip. If they don't hit both at the same time, you can get the wheels moved in or out to make them fit the wheel well. It would be a lot easier to move the wheel out (spacer) than it would be to move the wheel in, but it can be done.
Is any of this making sence? I'm no expert.
*I forgot to mention, I'm building a '64 Ghia, which has lower rear arches than the late model Ghias. So the rear will look lower and MIGHT have more room. That's just a guess.
Mike
'04 R32 Tornado Red
Old May 9th 2003, 09:54
Mr.Elect.Wizard's Avatar
Mr.Elect.Wizard Mr.Elect.Wizard is offline
This is a subject that is void like a black hole... Obviously some people have done this, as DORIGTT and I have seen. Anybody had time to look more into this or fit some cool combos over the last year?
Post what ya got...
----->www.aircoolers.org<-----
'71 Ghia
'69 Baja Bug
Old May 9th 2003, 10:12
vujade's Avatar
vujade vujade is offline
my guess is they have narrowed the trailing arms if they havent widened the fenders.
You may be able to run 7" wide rims with a 55et offset and a small spacer, but I bet you would still have to roll the fender lip.
If you want 8" wide wheels you will definitely need to narrow the rear or widen the fenders.
WinterJam 2010
Old May 9th 2003, 12:28
Narrowing the front is fairly straight forward... But do you know how narrow you can go without removing the shock towers?
And, how do you narrow the trailing arms? Cut and remove metal?
'71 Ghia
'69 Baja Bug
Old May 9th 2003, 12:34
vujade's Avatar
I believe you can go with 1.5" per side of narrowing on the front without removing the towers.
I believe there may be a tech article for narrowing the rear trailing arms.
WinterJam 2010
Old May 9th 2003, 12:58
tech article here?
'71 Ghia
'69 Baja Bug
Old May 9th 2003, 12:59
never mind... found it... thanx...
'71 Ghia
'69 Baja Bug
Old February 22nd 2008, 12:16
vwdevotee
I'm eyeing 8 inch wides on my rear also ('73 Ghia). Any news? I measured from teh outside of my current tires (EMPI 8 spokes, very close to the fender) to the spring plate and got 10 inches. I also measured at the top to the inner fender and got 11 inches. It looks like everything will fit, I just want to hear from someone who has done it before I drop 2500USD on wheels and tires.
Old February 22nd 2008, 13:51
DORIGTT's Avatar
Hey flatIV,
What brand and model tire are you using? I would like to research the specs (physical dimensions).
What are you using for rotor/drums to attach those wheels/rotors?
