Old August 30th 2009, 11:26
redhot redhot is offline
Simple brake upgrade
Hi,
The current setup is stock Beetle front discs and late model drums in the rear.
I want to make a small upgrade, but don`t think I need any large Porsche brakes.
I have laying around a new set of Talbot front calipers - larger pistons
Also - in the rear I`m either going to use Type 3 late model drums - larger brake bands and drums, or perhaps 914 disc brakes? Any other options?
Is the 914 front brakes similar to the Beetle setup?
ps: do anyone know what parts CSP are using for their rear-brake setup?
The car is a 1970 1200, swing-axle.
Old September 1st 2009, 05:09
Ok, so I found out this.
Many uses the 914 discs, and machining down an old drum from the Beetle to work as a hub for it.
The calipers are usually Golf, Passat etc, and some custom bracket made up.
So the conclusion probably is that 914 is more difficult than 924; but how does these parts fit on a swing-axle? Same brake ratio?
Old September 1st 2009, 19:11
Found this articel while reading; given that the brakes on the 914 and Beetle are the same, then the same modification should be possible. Anyone got/can get specs for the BMW caliper vs the Talbot one?
http://www.pelicanparts.com/techarti...W_calipers.htm
Old September 2nd 2009, 14:01
I think the 914 front brakes use a wider calliper bolt spacing than the Beetle, In pretty sure its the same as a late Type 3.
Old September 4th 2009, 05:10
I found this for the 914 calipers and late type 3: Lochabstand 76mm
Guess you were right
