Old January 26th 2010, 19:40
Natefank Natefank is offline
944 trailing arms, why?
why does everyone use the 944 trailing arms? is it cuz they already have the disk brakes? thanx
Old January 26th 2010, 21:52
Bug@5speed(US)'s Avatar
Sometimes:
- for increase track.
- easier to adapt Porsche brakes
- different PCD for wheels due to the 944 stub axles.
Comes to mind.
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old January 27th 2010, 08:41
evilC's Avatar
evilC evilC is offline
And the alloy ones look pretty!
Old January 27th 2010, 09:56
Jim's Avatar
Jim Jim is offline
lightweight
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old January 31st 2010, 21:02
flat flat is offline
Originally Posted by Jim View Post
lightweight
not sure on that one.... I've been meaning to scale the alu arms compared to the VW/944 steel ones. I'll try and do that and get back with some hard numbers.
www.vdubengineering.com
Old February 10th 2010, 17:11
verbeekb's Avatar
verbeekb verbeekb is offline
The VW steel arms are a lot lighter than the Porsche steel arms though.
1970 917 Poser
1972 Brunette
2004 VW Sedan
2005 VW LT 35 2.5 TDI
www.karrera.net
Old February 1st 2010, 04:17
Jim's Avatar
Jim Jim is offline
That would be very interesting Lanner! Always i was wondering if the Alu arms were lighter than the steel.
Old February 1st 2010, 05:06
evilC's Avatar
I've got a gut feel that the alloy arms are actually heavier! The beefy size of them plus the extra connecting bolts all adds up to a noticeable extra IMO. But there again I might have been comparing some seriously rust bug trailing that had rotted away some weight. I would be interested in the results.
Old February 1st 2010, 05:56
There's a big thread on comparing the weights on the french gl forum. Assembled with brakes, they are about the same...
Old February 1st 2010, 10:37
Simon Simon is offline
944 aluminum-alloy with bumpstop 6,816 kg
944 aluminum-alloy without bumpstop 6,810 kg
(these are the 2 different styles of alumium-alloy trailing arms, not the same arms with the bumpstop removed!)
Both measured with the wheel-bearing (800g) and the stock 944 inner bushing in place.
I haven't measured my stock trailing arms yet, since I'm too lazy to disassemble the drum-brakes :P
The difference will mainly depend on the brakes you want to run.
Some more weights here (in Dutch):
http://www.keversite.nl/forum/viewtopic.php?f=5&t=17066
Old February 1st 2010, 16:01
so then the main reason is the brakes?
Old February 1st 2010, 17:51
chug_A_bug's Avatar
and for the exra 25mm track
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old February 2nd 2010, 13:21
jmd's Avatar
jmd jmd is offline
that is why I did it... brakes and width addition.
Old February 2nd 2010, 13:29
Jim's Avatar
Jim Jim is offline
Anyone with the weight differences between steel and aluminium???
Old February 2nd 2010, 17:57
I put steel arms and brakes on my daily 1303 to increase the rear track, I'm using 17x7 55 ET wheels and the track increase from the steel 944 arms worked out just right so I don't need spacers.
On my other 1303 I have alloy arms, I measured drum face to drum face on my 1303 which had type 3 rear drums, it measured 1405 mm when I fitted 86 alloy arms it now measures 1490 mm face to face. The CV bolt flange is about 10 inches (5 inches per side) further out, but owing to the short 86 stub axle length I didn't get a 10-inch increase in track.
