Old February 16th 2010, 04:31
Bogara_ZO's Avatar
Wheel (and tye) weight
hi all.
Basically I'm interested in what you think, is it possible that a 2 or 3 pcs wheel in the same size is heavier than a normal alloy wheel? (not magnesium)
BTW also exact wheel weights are well come, maybe can be useful for those who are looking for new wheels. If you are in the game, please attach a picture and a weight of the wheel you are using or you have info of (mainly porsche rims I guess) I'm sorry if there is an existing topic for this.
Old February 16th 2010, 14:04
chug_A_bug's Avatar
cool topic...
I have a set of BBS RC w/o rubber they come in at 17lb
17X8
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old February 16th 2010, 16:54
Originally Posted by chug_A_bug View Post
cool topic...
17X8
One of my favorite wheels! Yummy.
Old February 24th 2010, 04:14
Bogara_ZO's Avatar
thanks for sharing. anybody else?
Old February 24th 2010, 08:36
evilC's Avatar
evilC evilC is offline
The 2/3ps wheels are definitely heavier due to no less than the thickess of the connecting flanges and the stainless bolts. The problem with giving weight for combinations of rim and tyre is that as you would expect the rims all vary but so do the tyres. Obviously, a new tyre is heavier by a good amount than a worn tyre also, i have found that the side wall thickness varies considerably between makes. I have some Vredstein Ultracs that have a 3mm sidewall whereas the Goodyear GS3s have a 5mm side walls with steel reinforcement. I doubt whether you could formulate any useful comparisons with the limited range that will be presented here.
