Old March 16th 2012, 17:59
Mr Big Mr Big is offline
Custom 5x108 pcd Beetle hubs for sale. £40ono
As I have changed my mind and gone for Porsche wheels I no longer have a use for these.
The fronts were blank beetle front discs turned down to create a hub and then drilled/tapped for the correct stud pattern. Currently the discs are mounted on the back of the hub but there is no reason why they couldn't be mounted on the front depending on your setup.
The rears are 924 drums turned down and drilled/tapped to the right stud pattern. Being a 924 part the original pcd was 4x108 so one of the original holes is used and had been helicoiled in this case so work with the M14 studs I was planning to use.
The front discs alone cost me £110 let alone all the machining work etc.
Obviously, there is more work required, caliper mounts, disc sizes etc so this not an 'off the shelf' solution!
I'm asking £40 ono as I have no idea what they're worth. If you feel otherwise and are genuinely interested then drop me a line.
Cheers,
Craig
1969 German Looker in progress:
1776 turbo EFI motor (eventually!)
Built IRS Box
944 Turbo Brembos (Fr)
964 C2 Brembos (Rr)
