Old November 25th 2002, 12:58
901 with T1 motor
How well does a 901 tranny work with a T1 motor? Was planning on using a t4 motor in my 61 rag, but that got put on hold. Will a 1600 or 1700 t1 have enough power to make use of the 901?
63 356b time capsule
948 project
Old November 25th 2002, 13:03
kdanie kdanie is offline
The gearing for a 911 trans might be a little tall. A 901/902 5 speed from a 912 should work well.
ken
Old November 25th 2002, 13:09
The tranny is a 901 converted from a 914, haven't tracked down the gearing yet.
948 project
Old December 3rd 2002, 16:13
Pillow's Avatar
Pillow Pillow is offline
To add to the questions.
What throw out arm and pressure plate are used in such a conversion?
I am looking at a 901 with T4 though which is a little different.
Hopefully picking up two 901s this weekend. Not sure of origin though, I guess 914s.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old December 3rd 2002, 17:19
With a 901 and a t4 motor, you can use the 914 flywheel and bits.
I need to find out what to do to a T1 flywheel to use the 901, seem to remember something about the pilot bearing.
948 project
Old December 4th 2002, 12:03
typ4boy's Avatar
typ4boy typ4boy is offline
ive found the best way round this is to use a wasserboxer crank either 69mm or if you can find one 76mm from 2.1, this has type4 5 bolt fixing so can use 914 flywheel. to fit this in type1 case machine centre and rear main to type4 size. hey presto !regards Lee.
Old December 4th 2002, 15:15
Pillow's Avatar
Big DUH on my part. Thanks for pointing out the obvious :silly:
I was thinking in terms of the T1 tranny and the starter would not fit the teath of a 914 flywheel.
With a 901 tranny the 225mm flywheel, clutch, and pressure plate will be perfect.
Sometimes I get wrapped up in details and forget to take a step back for the obvious!
Thanks,
Adrian Pillow
Old December 19th 2002, 21:09
Michael Ghia's Avatar
Cool 901 gearing
The 901 gearboxes which have come from 911's have lower gearing than the 901's which come from 914's.
The reason... the 6 cyl engine revs more and that is where the power is.
The 4 cyl has more power down low... so if you want higher gears... use a 914 box and convert... if you want closer gears and about the same overall final drive as a GT Bug box... go for a 901.
MG
Old December 22nd 2002, 08:19
914 gear ratios
The 914 gearbox ratios are as follows,
1st (11/34) 3.09:1
2nd (18/34) 1.89:1
3rd (23/29) 1.26:1
4th (27/25) .92:1
5th (31/22) .71:1
Final drive is (7/31) 4.429:1
All 914 gearboxes from the factory (4 cyl) had the same ratios whether they were tailshift or sideshift.
914/11 was the tailshift up to 1.10.72
914/12 was the sideshift box from then on.
Both can be converted but the later sideshift box needs a lot more parts to do it.
MG
Old January 5th 2003, 19:31
yetibone's Avatar
yetibone yetibone is offline
Wow, I didn't know you could use a 914 box in a bug! How do you get the ring gear to rotate in the opisite direction (mid engine drivetrain converted to rear engine drivetrain) Can the whole differential carrier assembly be removed, flipped over and reinstalled with the ring gear on the other side of the pinion ?
Which is easiest to use, the old tail-shifted ones, or the later side-shifted ones?
yetibone
Old January 7th 2003, 18:56
You got it....Flip the ring gear and replace the nose cone with a 901 piece. The tail shifter is the trans to use. The nose cone is hard to come by at a decent price. In the long run, I think it is cheaper to get a 901/902 from a 911/912.
ken
Old January 12th 2003, 21:56
yetibone's Avatar
Is it possible to use a T1 engine with T1 flywheel on a 901 transmission, or would the starter/ring gear mesh not be possible?
Also, will the input shaft fit into a T1 gland nut?
This is probably a stupid question.
Yetibone
:stupid:
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old January 13th 2003, 03:48
Richie's Avatar
Richie Richie is offline
Short and simple, it fits and you can use the T1 starter.
Cheers
Richard
Old January 13th 2003, 08:17
yetibone's Avatar
DURN!! That's quite contrary to what I thought. Time to beat the bushes for us a beat-down donor 914!
Bone+Y
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old January 13th 2003, 10:50
yeti,
I've got a 901 and two 914 transmissions for sale, and I'm just down the road near Southern Pines. Let me know, I can hook you up.
948 project
