Old March 13th 2003, 07:15
paul_f's Avatar
paul_f paul_f is offline
944 steel arm - bolts
I have just received my 944 rear arms and brakes (the steel ones) for my splitscreen IRS conversion.
I am currently having my spring plates modified for the 944 arms - do the arms bolt onto the stock spring plates with 4 bolts, 3 short normal style ones and then a different kind in the centre - an eccentric one perhaps (If so what does this one adjust?).
I am also going to use the 944 bushes etc, can anyone tell me what is used to fix this to the trailing arm brackets - is it a long bolt with a nut on the other end, or is like the type 1 style where the clamp has a thread in it which the allen bolt attaches too.
My reason for asking is that I was supposed to be supplied with all the fixings, however I only received 3 bolts that look like the type 1 ones for fixing the and two long bolts with nuts that look more like shock bolts than the bolts to attach the arms to the clamps.
Paul
Old March 14th 2003, 02:54
Superman
This should help:
http://www.pelicanparts.com/944/944_...3-85/Pic41.jpg
