Old May 17th 2011, 10:23
daddycool daddycool is offline
Suspension Arm Help
Hi guy's looking for some advice on some 944 rear alu A arms, I got these of a 89 944 they have the part no : 951.331.513.0 4 or 951.331.513.4R i have been doing some digging and think they are the wider track version as they dont have the bump stop cut out ? If they are the wider type what are the pro's and con's in using these ? I did want to use coil overs all round and a uni-ball on the rear, I have also looked at maybe flipping these to the opposite side allowing the lower shock mount to be up higher and then fitting turrets to the inner wing/rear seat back area ? The turrets could then be tied into a roll cage to brace it up ? Dont know if anyone has tried this before ? or if there are any issues with the caster / camber / toe in when attempting this ?
