Old May 6th 2003, 20:41
Rob's Avatar
Rob Rob is offline
Backfiring
Took the bug for another spin today, the longest one sofar.
She handles pretty good with the Konis up front (thanks Alex).
However, whenever I get to a stoplight, she dies. If I start her up again she idles fine though.
Also, when I get off the throttle the engine backfires a lot, does this mean it's running too rich ? Could this also be the reason the engine dies when I stop ?
Any info is welcome,
Thanks,
Rob.
Old May 7th 2003, 08:53
Post
Rob,
I think you said you have a 1600cc SP. Does that come with a 34 PICT-3 ?
I had the same problems with my engine (type 4) and it worked out that the idle circuit was lean. I don't think you'd have the backfiring with a rich circuit. I'm just learning how the carbs work as well.
Do you have any vacuum leaks ? This could cause the idleing to be lean as well as air is getting into the mix.
Hope this helps in the meantime.
Old May 7th 2003, 10:02
zydeco zydeco is offline
Also, look for exhaust leaks around the heads/j-pipes and at the collecter (assuming a header style exhaust system).
Brian
73 Superbeetle
