Old July 1st 2003, 14:27
bugsoup bugsoup is offline
best method for test fitting?
I am currently in the middle of my project. I thought I had chosen the right wheels (Design 90's) but my new brakes (996 w/ monoblocs) do not fit inside these. I am now wondering how I should determine the best size. I now know I need at least 17", but width and offset are still a question. I will be using the following combo:
Front: 996 brakes on '87 944 n/a hubs (with bearing adapters) and CB performance cast dropped spindles, '69 chassis w/ adjustable front beam and balljoints
Rear: 996 brakes on narrow 944 aluminum rear trailing arms and spring plates with a thin (about 3-4 mm) spacer under the rotor for clearance, center torsion adjusters (like offroaders use)
With so many differences from stock, I think I will be building the whole thing minus the wheels and tires. What is the best way to build mockups of the wheels I might use? I am considering these: Porsche 17" C2
any suggestions will be great
thanks
Scott
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old July 1st 2003, 15:28
Alex's Avatar
Alex Alex is offline
Boxster Rims will work. There size is 7X17 ET55 and 8.5X17 ET50.
You still might need a one inch wider fender in the back. Not a 100% sure about that. If you give me a month or two I know for sure.
Then I will have mine fitted.
