Old June 25th 2003, 17:22
Bad bug's Avatar
Bad bug Bad bug is offline
Porsche 911 cooling
I recently saw where some information was given about 911 cooling kit in the tech section. They also gave a name for a supplier he's said to make one of the best kits. Where does he live and does he have a e-mail or website.
Old June 25th 2003, 17:41
vujade's Avatar
vujade vujade is offline
You are talking about the Klaus kit.
I believe Alex said Klaus is not selling that kit out of Germany because he has patents on it in Germany & is afraid of people duplicating it out of his country.
WinterJam 2010
Old June 25th 2003, 21:57
Bad bug's Avatar
911 kits
Do you know how much this kit cost.
Old June 25th 2003, 22:43
Alex's Avatar
Alex Alex is offline
About 370$ for the shroud and approx. another 300$ for the ring and strap. You need to get an 11 blade fan and get it turned down to 225mm and a Porsche alternator.
This are just estimates and depend on exchange rates as well.
Old June 25th 2003, 22:47
Bad bug's Avatar
911 kits
But wouldn't they sell the 11 blade fan already turned down to 225mm.
Old June 25th 2003, 23:24
Alex's Avatar
Yes. But you could save some money.
The complete kit will cost you about 1000$....or a bit more...depending on the alternator.
Old June 26th 2003, 06:01
Alex/Badbug,
I also understood that the case requires machine work that will comply with his kit and Klaus can probably do that best (or as the only one). I don't know (but image not) if he would have a problem if you would send him your case and order the whole set and send it to the US. Does cost quite a bit tho...
Walter
