Old August 21st 2002, 14:07
blue4400 blue4400 is offline
944 trailing arms
Has anyone tried put the trailing arms off a porsche 944 onto a beetle? I heard it fits and it drops the rear too? Does it bolt right up, what year do I need?
Old August 21st 2002, 21:12
DORIGTT's Avatar
DORIGTT DORIGTT is offline
No problem
Swap out the mounting bushing for the beetle version and they bolt right up.
I'm referring to the steel arms by the way. I believe the aluminum arms work the same way with the exception of widening the track.
Old August 22nd 2002, 19:04
lightning bug's Avatar
I believe the steel 944 arms are the same as the Beetle with the exception of a camber adjustment on the 944. If so, IMHO, it wouldn't be worth it. The alum. are lighter, yes, but you will widen the track, as said above.
Julian
'74 Super
Old August 22nd 2002, 21:57
Superman
The above posts are correct. Also remember the spring plate will have to be changed also.
